Results 61 to 73 of 73
Thread: Transom repair
01-23-2017, 03:50 PM #61Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Hows the compression strength?
01-23-2017, 09:22 PM #62
I did some comparison of density and tensile strengths between the Diviny-cell H80 and the Corlite pet in the same thicknesses, and found the Corelite about 1/3rd stronger, and @ $2.31 per sq/ft. in 1/2 thick for core replacement. Much more reasonable in cost. At about 1/3rd the cost.
I am doing some "testing" with samples received Saturday in the mail. I like what I see, but will reserve judgment until I see how well it adheres to a piece of fiberglass.
Also like the look and feel of the Corlite board 25-30 lb./ft3.
Going to do an adherence test on it as well. It looks like you could drill and tap threads (don't know why you would do this, but it gives you an idea of it's density)...don't know yet, but will find out. At 2" thick it's just under $12.00 per square ft. Very strong stuff. So for a transom piece 18"x41" that works out to just over $60. Compare this to Coosa board?
Will post results when done.
I am hopeful, but we will see......
James H.
01-24-2017, 07:30 PM #63
Yes, just now went back and compared those numbers...had to use a conversion chart MPa to PSI. One set of spec's was in PSI (Corelite Pet) and MPa (Divinicell).
Compressive strength for Corelite Pet 228 PSI
Compressive strength for Divinicell H80 203 PSI
Compressive strength Modulus Corelite Pet 17,727 PSI
Compressive strength Modulus Divinicell H80 13,053 PSI
Honestly...I don't know what Modulus means, but will google it..................after I have a beer
Xstream, please feel free to double check me and my before beer math...
Another set of eyes on this is a good thing, specially a guy that knows what he's looking at...
I'll attach both PDF files....one from each manufacture.
Cross eyed and thirsty now . Off to the fridge
James H.
Slimm liked this post
01-24-2017, 08:10 PM #64Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I have a feeling, and i'm not downing the corelite at all but when the coosa or divinnycell has some glass on it the compressive strength will go way up. And as far as adhesion, both will have to be sanded for the best grip. The core lite is plastic and contains oil, so not ever gonna get as good a bond imo. So it comes down to is it good enough? I would say yes.
W2F a V-King thanked for this post
01-24-2017, 09:24 PM #65
That's good to know. Hadn't thought of that. I'm using epoxy if that makes any differences. Corelite claims no problems with adhesion with all 3, polyester, Vinyl Ester or Epoxy.... but if it has oil in it, that does raise a question.
I did get my samples from them and the Corelite board, 25 or 30 lb./t\ft.3 is pretty impressive. I will be bonding/glassing my stringers to it. Isn't polyester or Vinyl Ester petroleum based?
Guess I need to contact Corelite and ask some more questions. Great customer service. Easy to talk to.
Will let you know how well or not it sticks to each other.
Thank you,
James H.
Timothy Hoffman liked this post
01-25-2017, 08:11 AM #66Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
It would be easy to equally grind both coosa and corelite pcs. and then lay in 1 pc of 1.5 oz glass with the resin of choice, clamp for a few days then try and break apart with a chisel on the edge and see which one keeps its bond and which releases.
01-28-2017, 02:49 PM #67
01-29-2017, 02:27 PM #68
Hate to rehash this old part of thread but this site should be educational and this is worth addressing. Pad bottoms are faster and safer than a sharp v keel in many applications particularly light fast boats. Pads actually prevent chine walking, whereas v's chine walk certainly and can't be aired out like a pad. Chine walking with a proper pad bottom is usually caused by lower unit drag, excessive weight and poor driving, among other things. Look at all of the best hulls out there, they all use a type of pad bottom. V's can be fine in some applications and especially heavier off shore boats that don't air out, but Pads are safe, fast and stable.
FMP liked this post
01-29-2017, 07:39 PM #69Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
01-29-2017, 09:03 PM #70
01-30-2017, 11:17 AM #71Member
- Jul 2016
- Winchester ky
- 68
- 20
Pics of my Kona are on page one, what do you think of it?
03-22-2017, 06:06 PM #72
im removing my trans from the inside on friday,do i want to leave any of the old glass around the edges when i cut it out or cut all the way to the edge ? i have only helped with a trans. never done one on my own.any advice would be appreciated
03-23-2017, 09:04 AM #73Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Take it all out and start out fresh. Grind back to the good solid glass wherever you plan on repairing.
Transom Repair
By 2strk4ever in forum Fiberglass and Composites DiscussionReplies: 11Last Post: 04-11-2009, 12:57 PM -
Transom Need Repair?
By MrPhotographer06 in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 05-17-2008, 09:07 AM -
transom repair 2
By nstaller in forum Fiberglass and Composites DiscussionReplies: 6Last Post: 06-13-2004, 12:38 AM -
transom repair
By yamahadog in forum Fiberglass and Composites DiscussionReplies: 10Last Post: 08-04-2003, 09:25 PM -
transom repair
By Pete in forum General Boating DiscussionReplies: 2Last Post: 09-05-2001, 08:45 PM
