Results 1 to 15 of 27
Thread: Hydraulic steering
10-30-2016, 12:44 PM #1Member
- Jun 2015
- Victorville, CA
- 78
- 12
Hydraulic steering
I'm having my boat rigged with hydraulic steering with the installation of my new power plant. What are the advantages of this conversion? I've been told by my mechanic that's rigging the motor that I'll love it. I wanted to eliminate torquing of the steering wheel. It was a handful and with my new motor and increase in HP I wanted to eliminate it. My 24' Ultra has 425 hp and there is absolutely none so driving the outboard makes for an entirely different steering experience
10-30-2016, 02:59 PM #25000 RPM
- May 2001
- Maine
- 983
- 35
- 43
- 171
I had Jack Barsh install Hydraulic steering on my STV Euro when he built it and I love it. A lot better than the 2 cable rack system I had on my Baja.
10-30-2016, 05:07 PM #3
the only people that dont like hydraulic steering is those who have not got it or those who have not tried it.
its very good, no slop (providing its set up right) and you can let go of the wheel with no fear of it moving.
with a good well known quality hydraulic system you wont believe how nice it is.
Mine is an old system made by morse, now with all new seals and working 100%, I can let go of the wheel whenever I want and no way will the outboard move.
also I had bad torque from the wheel on the holeshot and all over the place at idle speeds, this has completely gone now and makes it a joy rather than a battle.
the engine dont move at all when on the trailer neither, so no having to strap it down to stop it swinging left and right when on the move.
I love it and cant see any pitfalls with it, just keep an eye out for any leaks and enjoy.
10-30-2016, 05:11 PM #4Member
- Jun 2015
- Victorville, CA
- 78
- 12
10-30-2016, 05:58 PM #5
Hydraulic steering for me was the only way I could have driven my boat after 2 heart surgeries, an Allison Grandsport ! Not a very easy boat to drive anyway .
10-30-2016, 08:52 PM #6
At the speeds and with the forces being applied by modern motors and props hydraulic steering is as much a safety issue as it is a comfort issue. Personaly I will never own another boat without hydraulic steering and to that point, it will always be power assisted. As was said above, those question the value of power assisted hydraulic steering are those who have never tried it.
Currently the state of the art power assisted outboard steering is Ultraflex Masterdrive. It can be had for the same price as any other power assisted system and it's arguably superior to even the Mercury Verado power assist system.Mark
NICE PAIR liked this post
10-30-2016, 08:57 PM #7
10-30-2016, 09:38 PM #8Member
- Jun 2015
- Victorville, CA
- 78
- 12
The Masterdrive is what I got.
10-30-2016, 10:18 PM #9
10-30-2016, 10:24 PM #10Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
WillySteve liked this post
10-30-2016, 11:06 PM #11
10-31-2016, 06:39 AM #12
It's probably a question with the nose mounted rams and the front mounted tie bar setup they use for their existing multi engine setup. A wing plate mounted tie bar and a balanced set of external rams coupled to their hydraulics would probably work perfectly. To your point, a wing plate mounted tie bar with their nose mounted rams, if installed and balanced correctly, should work fine too. That last setup is what builders of large cats with twin 400's are using with the integrated steering rams built into the 400's.
Mark
10-31-2016, 08:49 AM #13
absolutely love my hydraulic steering. Got it last year, and its the first hydraulic setup I've ever had. In the past, have had plenty of little boats with cables, and I'll never go back.
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
10-31-2016, 06:09 PM #14Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
No torque, lighter steering for docking, less feel at top end. Works for me.
10-31-2016, 06:18 PM #15
Hey Guys, don't forget to eyeball your stuff all the time, take a good look anytime something doesn't sound or feel right.
If you were to bang a fitting on the dock, not notice, and it popped .......... Just like a broken cable = no steering.
Also, know that your reservoir is full (enough, don't over fill) .... a slow leak, not detected (overboard or under deck) will eventually leave you with no steering or worse, a ton of slop when you need it the least.Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
home made tunnel thanked for this post
steering wheel alignment hydraulic steering (sea star)
By hst714 in forum Technical DiscussionReplies: 11Last Post: 06-21-2021, 02:44 PM -
hydraulic steering with steering wheel located trim buttons
By homeboy6658703 in forum Electronics, Audio Systems, and WiringReplies: 4Last Post: 06-23-2014, 07:43 PM -
Steering play in hydraulic steering?
By astro@ptd.net in forum Props, Setup, and RiggingReplies: 48Last Post: 08-18-2009, 01:17 AM -
hydraulic steering
By sonic 70 in forum Technical DiscussionReplies: 1Last Post: 04-25-2005, 07:34 PM
