Results 1 to 8 of 8
10-29-2016, 05:41 PM #1
Merc 260---not firing the injectors
Ok guys, at a loss here. I have a merc 260 that is not firing the injectors. I have a brucato ACU and I've swapped the acu with my buddies, still get the same results.
Fuel pressure is good(39psi), voltage is good(12.6)all 6 cyl are firing and I indexed the fly wheel...I pulled the fuel rail and injectors to see if they're shooting gas...I only plugged two injectors up but they only spray once, sometimes, with the starter engaged about 6-7sec...
Any help would be greatly appreciated. Thanks in advanceALLISON XB2002
Merc 260
Hydrostream Vector-Sold
Nitro-Sold
Sylva deck boat w/ 225 merc-sold
10-29-2016, 08:02 PM #2
Check your harness ground.
Quartermaster
XB2002 W/S3000
10-30-2016, 12:36 PM #3
Injectors should have batt power on the red/yel wire, ECU grounds the injectors to fire them. Red/yel wire gets power from the starter solenoid.
10-30-2016, 08:33 PM #4
Outside power pack. It sends signal to let injectors know when to fire.
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
David - WI liked this post
10-31-2016, 07:15 AM #5
Thanks for all the inputs guys. I literally checked and double checked everything. My buddy read a forum with a similar problem and they said it was the switch box... so we swapped the injector wires to the back switch box and she fired up... ugh..
hope this will help someone in the future...ALLISON XB2002
Merc 260
Nitro-Sold
10-31-2016, 08:35 PM #6
Yeap i had it happen before
10-31-2016, 08:47 PM #7
11-01-2016, 06:52 AM #8
No dought
By clarkb in forum Technical DiscussionReplies: 0Last Post: 10-29-2016, 05:16 PM -
03, 200 merc?? Not firing need help
By knot<safe77 in forum Technical DiscussionReplies: 5Last Post: 05-11-2013, 12:13 PM -
Mercury Tech: 1999 Mercury Optimax Fuel Injectors Not Firing -- HELP
By Flat_Out in forum Technical DiscussionReplies: 6Last Post: 02-08-2011, 05:22 PM -
Merc Pro Max 225 firing
By gerry 56 in forum Technical DiscussionReplies: 1Last Post: 06-14-2009, 02:45 PM -
By Scott Tharpe in forum Technical DiscussionReplies: 6Last Post: 03-13-2006, 10:36 PM
