Results 1 to 1 of 1
10-29-2016, 05:16 PM #1
Merc 260---not firing the injectors
Ok guys, at a loss here. I have a merc 260 that is not firing the injectors. I have a brucato ACU and I've swapped the acu with my buddies, still get the same results.
Fuel pressure is good(39psi), voltage is good(12.6)all 6 cyl are firing and I indexed the fly wheel...I pulled the fuel rail and injectors to see if they're shooting gas...I only plugged two injectors up but they only spray once, sometimes, with the starter engaged about 6-7sec...
Any help would be greatly appreciated. Thanks in advance
--boat ran perfect last wknd. They only thing I did was charge the battery and put gas in it..ALLISON XB2002
Merc 260
Hydrostream Vector-Sold
Nitro-Sold
Sylva deck boat w/ 225 merc-sold
Mercury Tech: 2.5 Merc firing problem
By DWD in forum Technical DiscussionReplies: 8Last Post: 10-07-2016, 12:18 PM -
03, 200 merc?? Not firing need help
By knot<safe77 in forum Technical DiscussionReplies: 5Last Post: 05-11-2013, 12:13 PM -
Mercury Tech: 1999 Mercury Optimax Fuel Injectors Not Firing -- HELP
By Flat_Out in forum Technical DiscussionReplies: 6Last Post: 02-08-2011, 05:22 PM -
Merc Pro Max 225 firing
By gerry 56 in forum Technical DiscussionReplies: 1Last Post: 06-14-2009, 02:45 PM -
By Scott Tharpe in forum Technical DiscussionReplies: 6Last Post: 03-13-2006, 10:36 PM
