Results 1 to 15 of 18
Thread: Big ole 275 Johnson
10-29-2016, 09:55 AM #1
Big ole 275 Johnson
re-adjusted everything lets see how that does
https://www.youtube.com/watch?v=d2gIdMRwfuM
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
SCT thanked for this post
10-29-2016, 02:05 PM #2
ok pointer is straight dles at 500 600 ish in gear but 1100 out of gear
cant get that to come back down ?
to windy to go for a run yet this is at the dock
for sale
10-29-2016, 04:04 PM #3
Not sure bout your idle problem, but I sure do like the video......you omc guys and your johnsons!!
10-29-2016, 05:42 PM #4
for sale
10-29-2016, 06:01 PM #5
You can't set the idle on anything omc without it in the water and or under load.
delawarerick liked this post
10-29-2016, 08:27 PM #6
for sale
10-30-2016, 10:55 AM #7
The OMC Factory Reps used a Magnahelic gauge to set the idle. They worked great. There was a kit that came with them, but when I got mine there were no more kits. I had the parts made by a small parts maker. Expensive, but worked great. This was with the big 3.6 carbs on a 4.0 liter. A little time consuming but great results. You have to be in the water, and not on a trailer just backed in, and moving at idle. Really takes two people.
10-30-2016, 02:10 PM #85000 RPM
- Jan 2004
- lindsay on. canada
- 370
- 14
- 13
- 68
- 34
10-30-2016, 06:03 PM #9
I'll try, I haven't used my gauge in about 20 years, but I only needed to use it once. From then on I never had a problem unless I stuck a piston. But the carbs never changed. I scanned the instructions and took pictures also. You need smooth water and someone to drive the boat that follows your instructions.
I used the large 3.6 carbs on modified 4.0 engines. They have all fixed jets. You first remove all the air bleed jets, some call them intermediate jets. Mine were all 22's. Then screw them into the adapters, and screw the adapters into the jet hole. Put rubber vacuum plugs on each hose barb in the adapters. The gauge has to be vertical. Attach the vacuum hose to the low pressure fitting on the gauge and the other end to the hose barb on the adapter, one at a time. You gotta get your mind right for this. Have the engine idling in gear with the water level about half way up the exhaust housing. You can't bury the engines in the water. Get a reading on each carb. Write them down and find what looks like the average. The gauge measures the amount of vacuum in inches of water for each carb. On a fixed jet carb you change the idle jet to change the reading, richer or leaner. On adjustable idle jets you just screw the jet in or out until all the carbs are about the same.
10-30-2016, 07:12 PM #10"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
10-30-2016, 10:16 PM #11
10-31-2016, 12:38 AM #125000 RPM
- Jan 2004
- 370
- 14
- 13
- 68
- 34
10-31-2016, 07:02 AM #13
for sale
11-09-2016, 04:42 PM #14
for sale
11-09-2016, 07:42 PM #15
Just get somebody to tow you around , so you can enjoy your boat.
afr liked this post
Johnson 175 faststrike vs johnson 225 ho fuel economy
By PARKBOY in forum Technical DiscussionReplies: 9Last Post: 05-14-2015, 09:20 PM -
OMC johnson 225 v6 vro technical date(comp. 225hp 2tEvinrude-suzuki-Johnson-mercury)
By Flabenk69 in forum Technical DiscussionReplies: 6Last Post: 05-02-2015, 11:27 AM -
OMC Tech: Mixing and matching Johnson 140 powerhead to johnson 200 mid section and lower unit
By stonebreaker in forum Technical DiscussionReplies: 11Last Post: 04-16-2012, 07:24 PM -
OMC Tech: 1990 johnson 225 powerhead to a 1994 johnson 150 midsection??
By 85HYDROSTREAMVECTOR in forum Technical DiscussionReplies: 1Last Post: 03-02-2011, 08:20 AM -
1978 Johnson Stinger vs. mid 1980 Johnson's
By fairbanks 1977 in forum Outboard and Racing HistoryReplies: 2Last Post: 08-04-2006, 06:40 PM
