Results 1 to 15 of 17
    Exclamation EASY Way of Adding Photos to Posts - Please Read
    Two methods for easy image uploading into posts
    1. Quickly inserting images into posts
    2. Inserting multiple images into posts at once
    1. Quickly Inserting Images Into Posts
    Below is a guide to show you how to quickly add photos to posts. By simply pressing the Insert Image button, you can upload photos from your computer. You may add as many photos as you want for each post by repeating this process for each image you would like added.Attachment 351251
    Attachment 351252
    Attachment 351253
    Attachment 351254
    Attachment 351255
    2. Enabling Easy Multiple Image Uploads
    By default, the forum has the Enhanced Attachment Manager enabled. This is a complicated system that is mainly designed for publishing features in posts. My recommendation is to switch this off, which would enable the standard image uploader.
    Enabling the Standard Image Uploader
    1. Go to your forums settings - **click here**
    2. Scroll down to Miscellaneous Options
    3. You will see a setting for Enhanced Attachment Uploading - switch this to OFF - shown below
    4. Press "Save Settings" and you're all set! You can always re-enable the enhanced image uploader anytime you would like.
    Attachment 350833
    Using The Image Uploader
    • To use the image uploader, when making a post just scroll down and click the Manage Attachments button.
    • This will open a window showing 10 upload fields. From here you can upload 10 images at a time into your post. Press "Choose File" for each photo you want to add to your post. After all of your photos are chosen, press Upload. This is shown below. You may repeat this process multiple times within the same post - there are no limits to the amount of photos that can be inserted into each post.
    • When you're finished with your photos and the text of the post, just submit the post!
    Attachment 350834
    Attached Thumbnails Attached Thumbnails uploads-attachments.jpg   upload-1.jpg   upload-4.jpg   upload-5.jpg   upload-2.jpg
    Central, PA
    I must be getting good at this, it made sense..........now if I could figure out how to turn a computer on...
    Quote Originally Posted by Bodhi View Post
    Hah, awesome!
    I just added a big update to the post at the beginning, for instructions on using the Insert Image button
    Jan 2008
    eatonton ga
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    10 mirage 1/4 master
    98 mirage 1/4master
  5. Likes Kcraft liked this post
    Jan 2008
    eatonton ga
    Lol that kinda worked
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    88 xr2002
    90 Stv pro comp
    98 mirage 1/4master
    Jan 2008
    eatonton ga
    Attachment 351392
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    88 xr2002
    90 Stv pro comp
    98 mirage 1/4master
    Thats the same way a few other sites do it, and works fine once ya get used to what to do. Thanks the update Greg!
  9. #8
    new york babylon
    Thanks Greg that's how I do it easy
  10. #9
    Quote Originally Posted by Robby321 View Post
    One thing not said is to get to image uploader, you need to "go advanced", then scroll down for "manage attachments".
  11. #10
    I just wanted to give this a quick bump to make sure everybody sees it.
    Thanks all,
  12. #11
  13. #12
    Jan 2008
    eatonton ga
    Attachment 357847
  14. #13
    Jan 2008
    eatonton ga
    cant figure out how to enlarge pics with phone guess I'll stick with the old way
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    88 xr2002
    90 Stv pro comp
    98 mirage 1/4master
  15. #14
    long island
    Attachment 357850
    kool
    IF IN DOUBT TRIM IT OUT
    1986 21`SUPERBOAT W/ECM-300XXX
    " The doctor says he's comin , but you gotta pay in cash "
    https://www.youtube.com/watch?v=DLBqhpM-AiU
  16. #15
    Cudjoe Key FL
  17. Likes Austin77777 liked this post
  1. Photos: EASY Way of Adding Photos to Posts - Please Read
    Last Post: 05-26-2020, 11:26 PM
  2. *** Posting Photos The Easy Way - Please Read ***
    Last Post: 01-06-2015, 04:01 PM
  3. Adding auto-info to my posts
    By tj309 in forum Computer and Forum Support
    Last Post: 07-19-2010, 10:07 PM
  4. How Gas Prices Work - An easy read:
    By at100plus in forum The Scream And Fly Lounge
    Last Post: 09-16-2007, 09:09 AM
  5. Why cant I read posts?
    By stvhelm in forum General Boating Discussion
    Last Post: 12-16-2002, 11:10 PM
