Results 1 to 5 of 5
Thread: Stator issue
10-26-2016, 01:21 PM #1
Stator issue
I just built a 2.5 200 cut to 260 specs Brucato ACU set to 260hp, 150 compression, 56lb reg, 16amp flywheel & stator and I'm burning stators at high rpm's...... I changed stator first 2 times then I changed flywheel back to light weight aluminum 40amp, stator, trigger, switch boxes and regulators and burnt stator again......What's ya'll take on what could cause this issue, I'm thinking wire harness.......
Wilson
10-26-2016, 08:33 PM #2
Damn, nobody has any ideas.......
Wilson
10-26-2016, 09:00 PM #3
Burning what? The charging side?
10-26-2016, 09:05 PM #4
Yes cause I lose fire on all cylinders and motor stops.......
Wilson
10-26-2016, 09:16 PM #5
I would look at the battery cables and battery first...make sure nothing is shorting out and load test the battery. The most common and frequent problem I've seen is loose battery cables...hand tight is not tight enough. Check the simple stuff first and go from there.
250xs top cowl melting common issue or is there an internal issue I should look for
By 150aintenuff in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 08-30-2015, 05:14 PM -
Mercury Tech: Issue with a Stator ass'y
By dompie99 in forum Technical DiscussionReplies: 11Last Post: 08-12-2015, 08:47 AM -
stator issue
By NosBoss in forum Technical DiscussionReplies: 6Last Post: 10-02-2014, 08:43 PM -
Stator issue on merc tech question??
By Mackzilla in forum Technical DiscussionReplies: 19Last Post: 02-06-2009, 11:29 AM -
Mercury Tech: Stator issue
By ctered in forum Technical DiscussionReplies: 6Last Post: 07-10-2008, 12:43 PM
