Results 1 to 3 of 3
Thread: 2004 250 Ficht blown fuse
10-24-2016, 03:36 PM #15000 RPM
- Jun 2011
- fl
- 139
Posting for a friend so excuse vague description or mechanical ignorance. The motor keeps blowing the #1 fuse to oil pump I believe. Has had EMM sent to DFI they sent back saying nothing wrong with it. New fuel pump starter plugs checked all connections . No codes popped up after last scan. Any ideas?
10-25-2016, 07:06 AM #25000 RPM
- May 2006
- 400
- 17
If the wiring and the oil injector are not shorted, the problem is in the E M M . This problem is seen more in the B R P built engines of 2002 and later. DFI should know about this problem, it is not real common but not unknown either.
There are 2 other companies that specialize in E M M repair -
CDI Electronics and Marine Computer Supply
10-25-2016, 10:07 PM #3
Looper with racing flywheel.. blown fuse
By rebible in forum Technical DiscussionReplies: 2Last Post: 08-10-2011, 07:08 AM -
possible blown fuse
By paul895fm in forum Technical DiscussionReplies: 2Last Post: 08-15-2010, 09:45 PM -
blown fuse on 2.4 200
By brokedad in forum Technical DiscussionReplies: 3Last Post: 08-02-2010, 03:37 PM -
Mercury Tech: HELP! Merc 225X blown fuse again, & again, & again
By tozlakes in forum Technical DiscussionReplies: 7Last Post: 03-11-2009, 10:06 AM -
225x blown fuse on motor
By jmirage04 in forum Technical DiscussionReplies: 5Last Post: 03-07-2009, 04:31 PM
