Results 1 to 5 of 5
Thread: rebuilding 245's
10-20-2016, 07:32 PM #1
rebuilding 245's
got motors all torn down the ring gap is around 30thou ,piston clearance 25 thou +
the motor's turned over by hand so smooth like there was no drag left ,when I unbolted rod caps you had to catch pistons on there way out , still had enough left to push the boat with 4 adults to 100 imagine what it will be when I get them back in spec ,wow.
10-21-2016, 05:37 AM #2
What was the cranking PSI and blow down before the tear down?
If it was good it may not change any thing after the rebuild.
10-21-2016, 06:33 PM #3
did leak down on a few cylinders around 8% i did not do a compression test ,i have run 4 sets of rings thru these bores my ring gaps were 27 to 29 last time i re rung , i had to wait 1 more summer to redo the engines the motors ran ok but had no low end and nothin on top 7200 was max rpm , where as i use to run 8000 before ,even with 26 pitch 7200 was max so i just cruised around for 1 more summer blew away few bass boats along the way ,blocks are going to stealth performance first , then to U.S. Chrome
10-21-2016, 08:16 PM #4
I hope your gonna have Dave massage the ports and exhaust a bit before they go to US chrome. I loved my twister but its been sitting upside down longer than I would like to think about. Mine put up some big numbers and always wanted to try and drag race it. I hate to even say it I might just put it back on the trailer next year and give someone else a shot at it.
10-21-2016, 09:45 PM #5
that is the plan dave's first before he gets busy with snowmobile motors , the twister would make great drag boat the interior out is another 150 #'s the twister is the easiest boat i have driven at 100 it take a nice set
20'' CLE 1.87 Needs Rebuilding
By aggiestckl in forum Lower UnitsReplies: 1Last Post: 02-12-2014, 03:41 PM -
Rebuilding a 280?
By Im2fast4uracing in forum Technical DiscussionReplies: 1Last Post: 07-19-2009, 06:26 AM -
rebuilding 427
By TNcumminsguy in forum Jet Boats, V-Drives and Stern DrivesReplies: 2Last Post: 07-14-2009, 04:00 PM -
OMC Tech: rebuilding a V-8
By hydrostream1 in forum Technical DiscussionReplies: 1Last Post: 02-09-2009, 09:24 AM -
rebuilding
By TTriton in forum Technical DiscussionReplies: 5Last Post: 05-02-2001, 08:19 PM
