Results 31 to 45 of 107
Thread: Allison Blow-over @Jasper2016
10-21-2016, 11:21 AM #31
10-21-2016, 11:43 AM #327000 RPM
- Jun 2001
- Crosslake, MN
- 2,005
- 40
- 70
- 482
- 530
- 3 Post(s)
Tomanytoys liked this post
10-21-2016, 12:54 PM #33
Limiting the trim mechanically is a good safety precaution for most situations but that alone can't prevent accidents like this one. You have to have enough trim travel to run in a tail wind situation and unfortunately thats just enough to cause a problem with a head wind or cross wind.
2 heavy duty Solenoids wired in series for up trim + Limited Mechanical Trim range is the best solution for preventing stuck solenoid issues IMO. I didn't come up with either of these ideas.....just things I've learned from other people over the last couple of years. Nothing is 100% but this gets you about as close as possible.Last edited by StratosVT; 10-21-2016 at 10:26 PM.
10-21-2016, 01:04 PM #34Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I wonder if people are putting 24v through 12v solenoids?
10-21-2016, 01:08 PM #35
10-21-2016, 04:41 PM #36
A good choice is a 24V aviation solinoid.Be sure to buy one that has a PMA.These will be old fashion quality stuff!---Oh be sure to get a start one,and not a master one.They look the same but duty cycle and amp ratings are different.Lamar# X61-0031 should do nicely.
10-21-2016, 07:42 PM #37Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Slimm liked this post
10-22-2016, 09:10 AM #38
This boat runs a physical stop inside the trim ram. The boat is good water conditions is drivable at the mechanical limit. It has lithium 36 volt up, so as Erik stated 40 plus volts. This is on a 24v relay. This didn't fail. Nor did the trim timer double trip, nor did a trim switch stick it was simply a 12 v solenoid that stuck while on 12v. Add the. Wind and waves and over it went. Like I said above a sequence of events.
2023 TUFF 25
Slimm, Tomanytoys thanked for this postSlimm liked this post
10-22-2016, 09:24 AM #39
WOW that was crazy,glad he is ok
Kevin_From_NJ, tux974 liked this post
10-22-2016, 11:48 AM #40
10-22-2016, 01:14 PM #41
My camera takes 6 frames per second, from the moment the boat went up until it was back into the water was just under 3 seconds. Felt like an eternity watching from the shore.
ragtopvet liked this post
10-22-2016, 07:11 PM #42
Incredible photos Kevin. Very scary! Glad Greg is alright. Those photos are just incredible.
10-22-2016, 08:13 PM #43
Happy he's ok.
“The bitterness of poor quality & service remains long after the sweetness of low price is forgotten”
10-22-2016, 08:19 PM #44
Greg is built like JJ Watt! It'd take a lot more than that to put him down! Glad you're ok Greg!
10-22-2016, 10:09 PM #455000 RPM
- Aug 2001
- long island ny
- 140
- 11
With all the big boat crashes and blow overs I'm glad to hear good news
Glad he is going to be ok
Allison blow out
By bigbluechevy454 in forum Technical DiscussionReplies: 46Last Post: 08-04-2013, 09:15 PM -
blow out
By Aggressive Machines in forum Technical DiscussionReplies: 55Last Post: 09-29-2009, 06:47 PM -
blow out!!!!!!
By quartershot in forum The Scream And Fly LoungeReplies: 14Last Post: 12-04-2006, 02:11 PM -
blow over
By JEFF BAKER in forum Technical DiscussionReplies: 0Last Post: 01-29-2002, 10:32 PM
