Results 16 to 23 of 23
Thread: Optimax overheat alarm
10-06-2016, 05:10 PM #16
Steady beep will put it in safe mode (gaurdian) and limit the RPM to about 2500. If it's not doing that, then there might be a wiring problem somewhere.
10-06-2016, 06:55 PM #17Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Steady horn might mean oil pump failure also?
10-25-2016, 05:11 PM #18
Force compressed air in the pee hole to clear the passage, you can also hook a temp gauge to the tan wire on the compressor to verify it is not the culprit
11-12-2016, 09:18 PM #19Member
- Jul 2007
- 39
I replaced both temp sensors in block and it went away. Also replaced all impeller parts
FORBESAUTO thanked for this post
11-13-2016, 03:08 PM #205000 RPM
- May 2001
- Maine
- 982
- 35
- 42
- 170
I had almost the exact same problem with my 2010 Sport XS 225 and if memory was correct it was a weak coil. The motor was under warranty at the time and Mercury changed all 6. I will see if i can find the paperwork and post EXACTLY what they changed... The alarm would come on at will and turn it on/off and it would reset.
11-27-2016, 11:04 AM #21
Looks like your port coolant temp was out of range (hi/lo). The SmartCraft info displayed is the starboard sensor, but the PCM looks at both sensors for overheat. So, if you weren't going into EngineGuardian, it was most likely that the temp sensor itself lost connection internally/externally, or the connection at the harness was suspect, and when you removed and replaced you re-established connection.
If you haven't erased faults with a diagnostic tool, the Freeze Frame faults will still be there, and it will say what was causing the horn. Either way, if it was a bad sensor and you replaced it, or an intermittent coil fault, it would be in the Freeze Frame Buffer. There will also be a run time associated with each fault, so you can see how long ago the fault happened based on current run time. This can also be helpful in diagnosing faults. If you have someone clear the faults for you now, anything new in there will be the only thing that shows, for easier diagnosis.
Glad you got it fixed, hope it stays that way!A problem is only a problem when viewed as a problem...
Kcraft liked this post
11-30-2016, 05:17 PM #22
a shorted sensor will read high or low and not show on smartcraft, and set an alarm seen it on mine.. 90 degree block would send sensor to 170 and alarm, really easy to find with CDS diagnostics
11-14-2017, 10:18 PM #23
Ur alternator may have fault im on the same mission right now i let off and steady beep goes away i look at temp water pressure all good but my voltage is lowat 11amp then when i let off and get back on throttle volts go back to 13amp check there
Overheat alarm on 01 merc 225 optimax
By jeffrey07 in forum Technical DiscussionReplies: 3Last Post: 04-09-2012, 03:47 PM -
XRI overheat alarm
By LAPLANT in forum Electronics, Audio Systems, and WiringReplies: 0Last Post: 04-10-2008, 05:09 AM -
225 Pm Overheat Alarm
By sprig in forum Technical DiscussionReplies: 3Last Post: 06-24-2004, 07:13 AM -
Overheat alarm tip....
By Superdave in forum Technical DiscussionReplies: 4Last Post: 07-26-2003, 10:09 AM -
Merc Overheat Alarm ???'s
By Clams Canino in forum Technical DiscussionReplies: 0Last Post: 09-02-2002, 09:48 PM
