Results 1 to 2 of 2
    Lake Coochiching, Ontario
    115 HO Etec Cowling
    I have had the cover off before, but either am having brain fade or a problem. Front levers, turn down and rotate. Same thing with rear lever. Cover doesn't budge. What am I missing?
    Canada, East!
    Pull latch out off the retaining stud, rotate down - sounds like your doing it right.
    Sometimes they are a tight fit. The air vent at the rear top of the cowl is a good spot to give it a little nudge, helps get the cowling off the side panels.
    pointer
  1. Etec cowling be modified to fit on older 3.0L omc
    By RayburnRacer in forum Technical Discussion
    Last Post: 01-30-2009, 03:49 PM
