Results 1 to 15 of 29
09-16-2016, 10:59 AM #1Member
- May 2009
- Orange
- 66
Mercury Power Tune? Your Experience
Hey guys,
I was picking up some parts for my boat the other day and spoke with a Mercury Tech about the mercuy power tune in a can. He told me its a great thing to do. He said fire it up spray it slowly into the carbs while running and then once the can is almost empty spray it all until the motor dies. Then let it rest for about 30 mins and fire it up. He said rev it up and itll smoke black really bad. Wanted to ask. How bad is bad? Should it not be done in my driveway? I would think on an open lake with people around wouldn't be much better. Also I just have a hose and muffs set up for running in the driveway so never like to throttle it up to high in the driveway in fear of not getting enough volume and pressure of water. What are your thoughts. This motor is an 86' 200HP Black Max. Never had power tune sprayed in it. owned it since 92. I may be WAY overdue. Just want to make sure I am prepared and if there are any concerns I should have on my mind to worry about. Thanks for the help
09-16-2016, 11:11 AM #28000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
Great stuff
09-16-2016, 11:21 AM #3Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
I do as the instructions say and then let it sit overnight, then run it. Try and launch somewhere that allows you to start up and get on plane fairly quickly. Warm it up and run wot for a few min. Cleans the rings and combustion chambers of carbon buildup. Removes some gunk/old oil from crankcase too.
Dave Strong, Slimm liked this post
09-16-2016, 12:09 PM #4Member
- May 2009
- Orange
- 66
So I'm gathering its best to do on the water. From what I have heard and read it will be some very thick black smoke? Is this true? Sounds like firing it up in the driveway and running it up to a 4k on the trailer isn't the best idea. It should have some load and full throttle. My concerns are a plume of black smoke following me on the lake.
09-16-2016, 12:10 PM #5Member
- May 2009
- Orange
- 66
Will burning this carbon off the piston and rings ultimately help my motor run cooler in the long run. Not sure if carbon build up will make a motor run hotter. It seems like it would because the motor would labor more.
09-16-2016, 12:15 PM #6Screaming And Flying!
- 14,753
- 381
- 1304
- 5602
- 11033
It's not as bad as all that. It's mostly castor oil smoke based from the smell. I like the smell, reminds me of 2 stroke dirt bike smoke. I like you, want a load on my motor when revving past idle. Might change plugs afterward since they may get gunk on them...
09-16-2016, 03:04 PM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
I like to get the motor good and hot , then fog it until it smokes , then shut it down. Let it work over night and repeat till the can is empty , then warm it up on the water and run it hard for a few minutes on the lake , then just go for a ride.
09-16-2016, 04:10 PM #8Member
- May 2009
- Orange
- 66
Sounds like I will have to wait until I get a chance to get out to the river or lake to do this. I will do it in the driveway a little the night before and then let it sit overnight and blow it out at the lake the next day.
09-16-2016, 04:35 PM #9Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
This is pretty much just SeaFoam from the description. Take the plugs out if you want and stick the straw in the chamber and try that but its about the same. If you do this turn the engine over a few times before you put the plugs back .
09-17-2016, 08:52 AM #10
Power Tune is great stuff.
09-17-2016, 12:51 PM #11
A lot of mechanics here in my area do it on a hose and never run it hard..... I've had a lot of arguments with them about doing it that way. Ya gotta run it hard a soon as you start it up preferably. I usually take the boat out with a spare set of plugs, fog it then drift and fish for half an hour or so the fire it up and run it hard back to the shop.
09-17-2016, 01:02 PM #12Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
09-17-2016, 01:08 PM #13
If you are gonna run it in your driveway put a rag or an oil absorbent diaper under your lower to catch all the crap thats gonna come out your exhaust JMO
09-19-2016, 01:31 AM #145000 RPM
- Jan 2004
- lindsay on. canada
- 370
- 14
- 13
- 68
- 34
that vid. the motor has no water running at all !!!! I was waiting to hear it start to rattle , but it didn't .... as was said to to the lake run it up to temp fog the motor sit and wait as long as you can take it and do it some more ..... start it up and get it going as hard as you can
09-20-2016, 09:35 PM #15
Power Tune - educate me
By Stoker1 in forum Technical DiscussionReplies: 34Last Post: 01-13-2014, 02:56 AM -
how to decarb my 300 promax with power tune?
By dschifan in forum Technical DiscussionReplies: 10Last Post: 02-22-2010, 01:02 PM -
Power Tune
By JW in forum Technical DiscussionReplies: 17Last Post: 08-07-2002, 07:51 PM -
Does anyone use Power Tune in their engines
By skatermike24 in forum General Boating DiscussionReplies: 3Last Post: 03-06-2002, 06:55 PM -
Mercury Power Tune
By skatermike24 in forum General Boating DiscussionReplies: 5Last Post: 08-01-2001, 06:34 PM
