Results 16 to 19 of 19
12-06-2017, 10:47 PM #16Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
Yes,same for any conventional motor,-and the impeller vanes will flip back and forth when changing directions without damage,Chris
12-07-2017, 07:19 PM #17
cheers Chris.
how long is the leak down done for at each setting ?
lets say at TDC for example, you load it up with 50 or 70 psi etc then look at the gauge, but how long for ? 2 minutes, 15 minutes etc ?.
or is this a straight away test within a few seconds ?
leakdown test id very new to me , so any info is good.
12-07-2017, 08:08 PM #18Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,272
- 215
- 30
- 585
The reading should stabilize a couple of seconds after the piston stops moving,Chris
12-09-2017, 01:39 PM #19
sounds like it is dead easy to do this test , ill have a go tomorrow and see if I can bugger it up ha ha .
leak down test
By 2XTREAM in forum Technical DiscussionReplies: 3Last Post: 09-02-2009, 07:24 PM -
leak down test ?'s
By boilerdawg in forum Technical DiscussionReplies: 35Last Post: 06-08-2009, 08:00 AM -
Leak Down test
By varmint2002 in forum Technical DiscussionReplies: 14Last Post: 05-30-2008, 01:04 AM -
What is a leak down test?? You ask?
By 86vintage in forum Technical DiscussionReplies: 2Last Post: 02-16-2007, 06:01 AM -
leak down test?
By cc1000 in forum Technical DiscussionReplies: 1Last Post: 08-24-2006, 06:26 PM
