Results 1 to 1 of 1
08-29-2016, 02:32 PM #15000 RPM
- Jul 2013
- medellin colombia
- 347
- 9
my 99 200 fitch fuel pump is stuck any way to free it up?
i bought a used low hour pair of 99 evinrude fitch 200s and they sat for about two years. i just fired one up, the second the fuel pump is stuck, the fuel smelled nasty. i was wondering if i let it sit in solvent for a few hours if it might free up. you can feel the motor trying to spin when i put current to it.
im wonder what the best thing to use is... im in colombia so no parts blaster or liquid wrench is available. crc is available also i think i can get acetone... not sure on a true penatrating oil tho.
if i have to replace the pump whats my best option oem of is there an afermarket avail? thx in advance for any info, rm
Water pump impeller stuck to drive shaft
By metalman1 in forum Technical DiscussionReplies: 20Last Post: 03-21-2015, 07:57 PM -
Stuck/varnished vst fuel pump
By bpalmer in forum Technical DiscussionReplies: 3Last Post: 07-01-2014, 11:59 PM -
How to remove stuck black max hydraulic trim pump
By graham180869 in forum Technical DiscussionReplies: 0Last Post: 03-28-2013, 03:10 AM -
Can merc powertune soak inside engine for a few days trying to free stuck rings ??
By baddjonny in forum Technical DiscussionReplies: 10Last Post: 06-25-2010, 03:46 PM
