Results 1 to 4 of 4
08-26-2016, 11:38 PM #15000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Suction side on impeller on merc lower ?
Witch side is the suction side on impeller to drill and tap fitting for low water pickup? ( 2.5 20" mid) thanks
08-27-2016, 09:24 AM #2
Drill and tap lower from either side or both sides depending on the cones requirements. Remove water pump base and you will see where the water comes in. Drill directly above the intake holes and just below the water pump base. Once you are in there you will see.
RockTeam Junk
08-27-2016, 01:09 PM #35000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Thanks,I will do just that. Im actually installing a transom mount pickup.
08-27-2016, 04:52 PM #4
If you miss, you will see oil...............
125 merc impeller question
By hydroguy21 in forum Props, Setup, and RiggingReplies: 1Last Post: 10-20-2008, 01:24 PM -
impeller ? for merc 2.0
By eautosales in forum Technical DiscussionReplies: 4Last Post: 06-23-2006, 08:36 AM -
Mercury Impeller Differences between Lower Units
By dry3 in forum Technical DiscussionReplies: 2Last Post: 03-24-2006, 04:06 PM
