Results 1 to 3 of 3
    Apr 2013
    Lexington, ky
    Occasional sneeze on start up
    99 Merc 2.5, about 5 hours on fresh rebuild. Using WH-22 carbs. This only happens after I warm it up and run down the lake to fish, shut it off and fish a while(hour or two) then fire up to move locations. Only happens once then starts right up and runs perfect, does not happen every time.
    Slimm
    minocqua, wis
    mine used to sneeze at start up below 75 so i turn fuel screw out another 1/4 turn on cooler days on whm carbs the fuel screw is + or - 4 jet sizes according to chart
  3. Thanks Slimm thanked for this post
    Likes Slimm liked this post
    Check your idle timing and bump it up until it smooth out at idle then back off the idle screw till its at the correct idle RPM in Gear.
  1. Sneeze at idle
    By Blown Up in forum Technical Discussion
    Last Post: 04-29-2013, 09:22 PM
  2. Mercury Tech: lean sneeze?
    By P man in forum Technical Discussion
    Last Post: 10-10-2008, 09:38 AM
  3. Lean Sneeze
    By Moonshot180 in forum Technical Discussion
    Last Post: 01-16-2008, 02:06 AM
  4. 2002 Merc. 150 occasional hard shifting
    By gw204 in forum Technical Discussion
    Last Post: 07-14-2003, 05:24 PM
  5. OMC - Lean Sneeze
    By DSP1 in forum Technical Discussion
    Last Post: 07-24-2002, 03:48 AM
