Results 1 to 9 of 9
Thread: CDI Racing ECU Info
08-26-2016, 11:57 AM #1Member
- Apr 2016
- Cayman Islands/Miami Florida
- 43
- 7
CDI Racing ECU Info
I have just bought my first efi motor 260 with a CDI racing ecu a36 box have any one run boxes, are they good? any advantages running these boxes are should I just sell an get a brucato boxes? Some info on these boxes would be appreciated thanks.
08-26-2016, 03:34 PM #2
A36 8200 RPM limiter 39 lbs, fuel pressure for 260 HP 2.5L. I run a CDI box on my F1 motor and spin it 10,000+. No problems with it. I have heard quality has went downhill on their stuff but I have not experienced this. I have run CDI stators, switch boxes , ecu's with no problems but I have others had problems.
08-26-2016, 03:38 PM #3Member
- Apr 2016
- 43
- 7
08-26-2016, 03:56 PM #4
I ran cdi ECU and electrics in f1 as well. No problems with electrics but I had 3 dud ecu's before I got a good one. That ECU is now 8 years old and works perfect.I also used a Brucato PCU which also runs perfect. It is now 13 years old and I now use it as a workshop test ECU. I just flash the required map.
Popey
08-26-2016, 04:06 PM #5Member
- Apr 2016
- 43
- 7
Thanks,where can I get it flash with the require map an injectors clean? an cost.
08-26-2016, 09:25 PM #6
From Tony Brucato. He can flash a fuel map to suit your engine and clean and recalibrate your injectors. He is a vendor on this site.
Popey
08-26-2016, 09:38 PM #7Member
- Apr 2016
- 43
- 7
08-28-2016, 04:40 AM #8
If its the 11350 CDI version. John Marles ( http://www.us1.cc/racingefiecuchips.html ) sells new chips with many different Curves for $75.00. Remove the cover and see it the chip is removable. If so forget a reflash. just buy whet ever chips you want. I switch mine from A 48 chip for my NOS Drag Motor and A 63 Chip for my Modified Drag with no NOS.
08-28-2016, 09:34 PM #9Member
- Apr 2016
- 43
- 7
thanks for the info
****omc 70 hp and 7hp racing info****
By smiles in forum Outboard and Racing HistoryReplies: 18Last Post: 04-28-2012, 05:01 PM -
Info About the RACING OUTBOARD 50-70HP
By AUS-ADZY in forum General Boating DiscussionReplies: 0Last Post: 05-23-2011, 07:56 PM -
OMC racing engine info.
By Jon.Bucy in forum General Boating DiscussionReplies: 4Last Post: 03-12-2010, 08:24 PM -
Info: VP RAcing Fuels
By Rocket in forum Racer's HangoutReplies: 0Last Post: 07-27-2005, 05:42 PM -
Info On Racing???
By shafercon in forum Technical DiscussionReplies: 2Last Post: 02-04-2004, 08:59 AM
