Results 1 to 6 of 6
08-20-2016, 08:33 PM #15000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
Mercury experts. New SSR HD hub vs traditional solid HD hub
It seems it was developed for large inboards swinging large props. It supposedly shifts with 20% less impact due to the soft rubber outer hub cushioning under low power then is locks solid under full load.
The traditional hub is considered solid as well, but shifts harsher...
Does the traditional hub give any more at an under load strike or are they apples to apples when under power?
Is there a plastic hub kit like that is available for the 1" shafts that will save gears? Or are these the only two choices?
If you are typically using 27-33p props which hub would be your choice?
https://m.youtube.com/watch?v=tYHXhujcqUk
Thank you in advance!Last edited by xb03fs; 08-20-2016 at 10:19 PM.
Dave Strong, NICE PAIR thanked for this postNICE PAIR liked this post
08-21-2016, 02:08 PM #2Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
08-21-2016, 03:35 PM #3
I was going to ask the same question. I see no technical reason this won't work just as well as the solid flo-torq and anything that can take some of the shock out of the gear case is a good thing.
Hard to believe no one has used it yet.
08-25-2016, 01:12 PM #45000 RPM
- Mar 2010
- Alberta
- 363
- 15
- 33
- 29
- 231
Reading the literature on it, my understanding is that because the Verados are so quiet the noise made during shifting is more noticeable or intrusive to the CC crowd that buy most of them. I think the benefit to the mechanical parts is very small given the loads at idle during shifting, and since it's a solid hub under power no portection there either.
08 Checkmate 2100br 250xs
08-27-2016, 07:42 PM #5Junior Member
- Aug 2016
- USA
It's not designed for inboards, the hub only works for outboard gearcases that use the 1.25" HD propshaft, which uses no thrust washer. It's not meant to be sacrificial like the Flo Torq 2 if you strike something. Under load, the prop engages the metal portion of the hub, and it behaves just like the solid metal HD hub.
The solid metal and the SSR are the only 2 options for the 1.25" HD gearcases.Last edited by Guzzoline; 08-27-2016 at 07:44 PM.
09-05-2016, 07:54 AM #65000 RPM
- May 2007
- STL
- 856
- 14
- 15
- 48
- 25
Surface gap vs. traditional style plugs
By silverbullet02 in forum Technical DiscussionReplies: 20Last Post: 05-18-2013, 08:20 PM -
Jet Drive vs. traditional prop propulsion
By jimbob1 in forum General Boating DiscussionReplies: 29Last Post: 11-12-2011, 02:34 AM -
Wraps, Paint and Traditional Graphics
By Still Crazy in forum General Boating DiscussionReplies: 10Last Post: 08-31-2010, 01:00 PM -
traditional steering vs. center steer
By Juggernaut in forum Props, Setup, and RiggingReplies: 10Last Post: 01-31-2010, 05:33 PM -
ATTENTION: Mercury OB experts - a question
By croSSed in forum General Boating DiscussionReplies: 16Last Post: 02-01-2008, 09:18 AM
