Results 31 to 45 of 48
Thread: Looper flywheel magnets
08-24-2016, 04:33 PM #31"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
Captain75 thanked for this post
08-25-2016, 06:31 AM #32Scream And Fly VIP
- May 2001
- Hickory NC
- 5,580
- 18
- 248
- 203
- 462
- 4 Post(s)
Pic you got off the internet is NOT a 60 degree flywheel it is however a DI flywheel. No center fire ring but has teeth for a CPS.
08-25-2016, 08:55 AM #33
I am going to say keyway points to dead center of 1 of the magnets. I have looked at 20 flywheels online and many point all different directions,however several point dead center to magnet. I looked at crossflow flywheel and they use 12 magnets with sets of 2 maybe 3/16 apart then 1" gap to next set , and keyway points to center of set of 2 magnets. I will have a answer for you from someone who will know later today.
08-25-2016, 08:57 AM #34
08-25-2016, 10:20 AM #35
Ok that would be wrong, keyway should point at edge of magnet without notch in it. What you stated in post #8 was wrong, charge coil is charged when magnet crosses coil and peak voltage is at center of magnet. Coil builds to center of magnet then drops off to end of magnet. CDI sent me these 2 pictures of looper flywheels that have never been on motor only on there test wheel to test stators and both point same way.
08-25-2016, 10:47 AM #36
08-25-2016, 12:25 PM #375000 RPM
- May 2006
- 400
- 17
The keyway to magnet orientation differs between the 1987 and earlier V6 looper flywheels and the 1988 and later models due to the different ignition systems
08-25-2016, 04:35 PM #38
You're absolutely right.... I spoke with CDI today too before I saw the responses here today (he said "funny, I had a guy call today about the same damn thing!"),
I do have two boats at the marina with 4 of these same engines running fine with the magnets oriented the way they are in the pic I posted. Guess I'll pull the magnets off this flywheel and do them the way Racer originally says..............
Thanks for your help!Last edited by flabum1017; 08-25-2016 at 04:39 PM.
08-25-2016, 04:37 PM #39
08-25-2016, 05:16 PM #40
At least you will know how well the loctite held! The other problem I see with using loctite is the flywheel gets hot, and that is usually how you break a bolt or flywheel taper with loctite on it,you heat it. I would think about ordering the BRP magnet epoxy kit from them.0431929
I always like discussions like this because I always learn something,never to old to learn something. Thanks FlabumLast edited by perfmarine1; 08-25-2016 at 05:26 PM.
08-25-2016, 05:24 PM #41
Loctite says 500 degrees........ If that flywheel hits 500 degrees, there won't be much of a motor left LOL...... seriously, I've been using red loctite in flywheels for a long time and never had any issues.......
I have a nickle glued to the shop floor with red loctite......... it's stuck pretty good..............
Loctite makes a bearing retention compound that's thicker and would probably work well too.Last edited by flabum1017; 08-25-2016 at 05:28 PM.
08-25-2016, 05:38 PM #42
08-25-2016, 06:09 PM #43
271......... 242 is blue if I'm not mistaken
08-25-2016, 07:05 PM #44Scream And Fly VIP
- May 2001
- Hickory NC
- 5,580
- 18
- 248
- 203
- 462
- 4 Post(s)
242 is blue, the factory epoxy does work well. Had to reindex the center fire ring on one today, it was from a 92 and the center does index different from 87 prior.
08-25-2016, 07:45 PM #45Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,090
- 1008
- 353
- 4286
- 1946
- 7 Post(s)
Is there a kit that includes magnets?
Omc looper flywheel magnets
By brussrude in forum Technical DiscussionReplies: 3Last Post: 10-22-2009, 12:53 PM -
flywheel magnets..v4 looper
By tony genovese in forum Technical DiscussionReplies: 2Last Post: 12-21-2005, 09:07 PM -
FLywheel magnets
By Darton in forum Technical DiscussionReplies: 2Last Post: 03-29-2004, 05:29 AM -
flywheel magnets
By natzx7 in forum Technical DiscussionReplies: 3Last Post: 09-14-2003, 08:26 PM -
Flywheel magnets
By Wile E. Coyote in forum Technical DiscussionReplies: 3Last Post: 07-17-2003, 04:55 PM
