Results 1 to 6 of 6
    Aug 2016
    San Diego
    Need help identifing this motor.
    I got motor a few days ago from an older gentleman. Said his son got it for his boat. Boat got sold engine stayed behind. On the block all I can find is a Letter A. and L2264 smaller with 333 stamped over it. on valve cover 329965. Throttle linkage 129996, and on each of the 8 carbs 397479 17 FKMX, and the bottom of engine a v8 Logo stamped on linkage is a circle with a square inside and a M inside square, Circle Square M.
    Was told 76 race motor, Been unable to find anything like it. Has to be some power because 8 carbs and motor is upside down so valves working opposite of what the norm is. no oil tank so must use a oilier. Thank you for any help
ID:	352889Click image for larger version.
ID:	352891Click image for larger version.
    Thank you
    Confuzed
    Attached Thumbnails Attached Thumbnails 20160810_224920.jpg   20160810_225131.jpg
    Ft. Lauderdale, Fl
ID:	352893By the carbs, it looks like a 1984 or 1985 275hp or 300hp Johnson or Evinrude outboard powerhead.
    Waretown, NJ
    Two stroke V8 OMC, no valves(except reed valves), no valve covers
  4. Likes vnemous liked this post
    Aug 2016
    San Diego
    Quote Originally Posted by Kevin_From_NJ View Post
    Thank you Flip the motor upside down and almost looks like a real v8 flat valve covers...
    Aug 2016
    San Diego
    Thank you gives me a place to start looking big bore looper this way I can make up my mind what to do with it.
    Aug 2016
    San Diego
    Thank you very much that what she is. They have one in a sandrail. I would throw it in my ranchero but not a good motor for anything but wide open throttle. I dont have a problem with that but will the judge understand???
    Once again thank you
  1. need help identifing motor
    By mountainfreik in forum Technical Discussion
    Last Post: 08-25-2010, 08:40 AM
  2. Any help identifing this motor
    By 97 TWISTER in forum General Boating Discussion
    Last Post: 03-10-2010, 07:29 AM
  3. Identifing props
    By Jacob in forum Props, Setup, and Rigging
    Last Post: 01-31-2010, 08:16 PM
  4. Need Help Identifing Boat
    By Corwin in forum General Boating Discussion
    Last Post: 07-04-2007, 07:10 PM
  5. Help Identifing an in line 6 SN.
    By Tom Smyth in forum Technical Discussion
    Last Post: 12-26-2006, 03:08 PM
