Results 31 to 45 of 76
Thread: 3.6 GT powerhead details
10-26-2016, 02:40 AM #31
Hi Frank
Thanks for the info. To my knowledge there are none of these V8's in England, hence no knowledge so I am on a big learning curve
10-26-2016, 02:45 AM #32
To prove the concept of my project, I will initially run with 8 carbs with float chambers so these (the inlet) will be horizontal. If successful, I then upgrade to EFI, CDI, and the 8 expansion chambers.
powerabout liked this post
10-26-2016, 06:31 AM #33Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
10-26-2016, 11:34 AM #34
Sorry, I mean with the crankshaft horizontal and putting on 8 separate carbs. Its a mid engined car so exhaust may run through the car and exit on passenger side. Lots of things to consider.
10-26-2016, 11:57 AM #35Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
did you have in mind to use the original carbs with adapters?
Perhaps lay the engine on one side so your inlet is horizontal might be easier?
Working out a coolant flow will be another challenge depending on how you mount it?Last edited by powerabout; 10-26-2016 at 12:03 PM.
10-26-2016, 12:44 PM #36
Yes engine will be on one side. I am waiting for arrival of engines from USA but I think I can cut the 4 dual carbs to make 8 independents each with a float chamber. Otherwise I will use 8 Mikuni as used on the Rotax engines.( I have lots of jets for them). With 8 you can tune each carb to cylinder requirements at circa 6800rpm (my CVT operational RPM) and hopefully avoid piston seizures.
Currently I am having to consider a tank of iced water on board plus radiators + fans to get to the operational temperatures suggested/recommended by Racer. I am also considering CO2 injection into the coolant as its much less weight than racing with a tank of iced water!
ANY thoughts/ideas on these problems, by anyone, appreciated since I am in complete new territory. and I love a challenge.Last edited by Hillclimber; 10-26-2016 at 12:46 PM. Reason: correction
10-26-2016, 01:01 PM #37Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I'd say electric pump(s) and radiators would end up being the easiest at the end of the day.
The carbs are individual its the throttle blades that are grouped into 4 lots of 2.
You might want to set up a bench to run the engine to ensure it runs properly before you do anything else.
Then lay it down in the workshop to get it to run after you alter the carbs.
www.epc.brp.com
Hillclimber thanked for this post
10-26-2016, 01:38 PM #38
Great for the help/advice !!
Just looked at the BRP parts list (thanks) and can see the throttle blade arrangement. Looks like a problem I can solve.
Electric pumps definite, I am taking no parasitic loss's from the engine. My calculations at the end of the full development programme is 525hp and a top ten placing at top England Hill Climb - Shelsley Walsh. Job done in 2019 when I will be 75yo and can retire gracefully.Last edited by Hillclimber; 10-26-2016 at 01:42 PM.
10-27-2016, 11:36 AM #39Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
here is some horsepower from a V8, I would hazard a guess that the only factory part is the crank?
http://www.screamandfly.com/showthre...ight=monty+efi
11-02-2016, 03:14 AM #40
you should use a mercury instead of an evinrude
http://mercuryracing.com/mercury-rac...-crate-engine/
11-02-2016, 03:34 AM #41
No - I only race two strokes!
11-02-2016, 09:41 PM #42
The engine has 8 single carbs from the factory.
11-03-2016, 10:52 PM #435000 RPM
- Jan 2004
- lindsay on. canada
- 370
- 14
- 13
- 68
- 34
you will most likely find the mikuni carbs easyer to deal with . The brp jets are getting harder to get and expensive ....jmo..
11-08-2016, 01:40 PM #44
Piston Rings for competition engines
All of my research and current deliberations of how to make the most out of the OMC 3.6GT powerhead indicate that one needs to increase RPM to get extra/increased power. My calculations indicate that the "Standard wide rings" are going to be travelling at their safe limit of 40,000 Ft/sec2 at 7000 RPM. What happens at 8 or 8500 RPM?
Previously, to increase RPM on other engines, I have converted to "Dykes" rings (L shaped - very thin - fitted close to piston crown - and OK for 100,000 ft/sec2) but the standard OMC pistons do not allow space for this modification.
My calculations of the 3.6GT with EFI + 8 separate expansion chambers + CDI conclude that 8750 RPM is where I need to be aiming and obtaining about 500 HP.
I.E. - The existing design pistons will fail.
So does anyone know if 3.6L pistons are available un-machined allowing Dykes rings to be fitted or is there an "After Market" supplier of Dykes ringed pistons?
ANY comments or advice appreciated.
Peter
11-08-2016, 03:13 PM #45
Might be time to contact Monty Racing and ask Gordon. He's got lots of these things out there, and in race trim, they turn waaaaay over 8750rpm.
Keith-
What are some details on this Black Max??
By Runnerguy41 in forum Technical DiscussionReplies: 15Last Post: 06-25-2014, 05:27 PM -
Details about 3.0L Hopups?
By Z06jim in forum Technical DiscussionReplies: 0Last Post: 08-27-2009, 02:40 PM -
CT River Run details?
By Pro300x24LD in forum General Boating DiscussionReplies: 38Last Post: 09-26-2007, 08:15 PM -
MTI 39 Cat at Miami - Photos and Details Here!
By Scream And Fly in forum General Boating DiscussionReplies: 17Last Post: 02-20-2006, 05:51 PM -
Some more E-TEC details
By Backfire in forum General Boating DiscussionReplies: 8Last Post: 02-24-2003, 03:05 PM
