Results 1 to 5 of 5
Thread: Rev limiter carb motor?
07-30-2016, 01:16 PM #1Team Member
- Oct 2002
- Meridianville, AL
- 453
- 7
How do you remove the rev limiter on a 2000 model 200 hp carb motor with CDM ignition?
Thanks, Pford
07-30-2016, 04:23 PM #2
It's in module located on top of engine. Will have to have someone remove it.Think Chris Carson can do it. CDI says they can but tried twice on one of mine and never got it. I finally switched to switch box ignition, much easier to deal with in performance situation.
07-31-2016, 09:28 AM #3Team Member
- Oct 2002
- Meridianville, AL
- 453
- 7
Thanks for the response. So I guess those are my only options?
07-31-2016, 10:12 AM #4
As for as I know. I would contact Chris and see. It was a few years back when I was trying and was unaware of Chris doing them. I like not having the timing delay in switch box ignition because easier to set timing and seems way more responsive.
07-31-2016, 01:03 PM #5Team Member
- Oct 2002
- Meridianville, AL
- 453
- 7
Thank you for the info!
How to remove rev limiter on a 200 carb or efi motor
By Shawn Junker in forum Technical DiscussionReplies: 2Last Post: 09-14-2013, 09:27 PM -
Bought 1997 Merc OS Carb 225 3.0, and parts motor EFI..Can I use efi on carb engine
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 02-19-2012, 08:59 AM -
Mercury Tech: how to remove rev limiter on 04 150 carb motor
By bigbluechevy454 in forum Technical DiscussionReplies: 5Last Post: 11-28-2010, 09:53 AM -
Is there a rev-limiter on a 2005 Merc 200 carb?
By WILDMAN in forum Technical DiscussionReplies: 11Last Post: 03-31-2006, 11:01 PM -
Merc Carb Rev limiter
By TTriton in forum Technical DiscussionReplies: 1Last Post: 04-21-2001, 11:05 PM
