Results 1 to 14 of 14
    Minnesota (play) / Michigan (work)
    Stator questions, 9 amp vs 40
    Have to get a 2.4 together for the weekend, can a lower amperage stator replace a higher amperage one? I have what I believe is a 9 amp and it would be replacing a 40.
    Thanks
    Not fast enough
    Yes, but you'll need to use a matching 9 amp flywheel, starter and rectifier. The regulators will be eliminated.
  3. Likes JRider liked this post
    fat fingers? my excuse is just bein' old.... ok, HEATHEN!.. ya "might" wanna edit... some of these folks or confused enough as is!......
    Is Heathen correct? Not sure what needed editing?
    Not fast enough
    Are the starter teeth count different or something?
    Not fast enough
    TX......somewhere?
    start over cause i'm tha one so confused today... got up this morning this way!
    Quote Originally Posted by JRider View Post
    yeah, thats what hes talkin' 'bout.. ya gotta check, some of tha early flywheels have different tooth count....
    Old??? Hell, I got that beat, old blind half crippled and ride around now with my signal light goin all the time
    TX......somewhere?
    what signal???
  9. #8
    Alright, got the matching flywheel to go with stator. Not sure what amperage they are but they are a matched set, should be good to go.
    Not fast enough
  10. #9
    TX......somewhere?
    teeth on 9 amp flywheel same as tha flywheel you're takin' off so tha bendix will engage right.... if ya old like me/us, easiest way (i can't count over 20) is put it on and see if starter will engage and turn it over.....
  11. #10
    Dec 2011
    Ludington michigan,on the shore
    Your forty amp is thicker than the thinner 9-16 amp.The latter two use the same flywheel.You can leave both regulators on the motor,just put the two yellow stator wires to one of them.and insulate the other two.If it ever goes bad,just switch the two yellows to the other regulator.
  12. Likes JRider liked this post
    what signal???
    Left or right, doesn't matter
    Sep 2006
    Minnesota
    Whichever one works. It's possible one was bad before hand and you didn't notice.
    If it isn't bad, you can leave the red wires from the spare hooked up. If the VR fails just transfer the yellow and grey (tach) wires.
    To fish or not to fish? What a STUPID question.
  15. #13
    TX......somewhere?
    j.... Heathen's talkin' 'bout turn signals in tha truck!.. ya gotta read tha whole conversation but i deleted most of it so ya got left out in tha cold............
    plus tha guy's reg. is tha water cooled version unless its been changed over....
  16. #14
    Sep 2006
    Minnesota
    I just got back from herding a first gen Cummins, a fiver, and a bass boat to Montana and back. Then got involved in 15 Windows 10 upgrades in 2 days. Besides, I'm too poor to pay attention.
  1. Mercury Tech: flywheel, stator, trigger questions
    By Deznuts3570 in forum Technical Discussion
    Last Post: 05-01-2015, 03:10 PM
  2. Mercury Tech: kill circuit and stator questions
    By 1oldmerc in forum Technical Discussion
    Last Post: 08-02-2011, 07:58 AM
  3. Questions about water cooled manifolds; why? Newb questions.
    By Cash68 in forum General Boating Discussion
    Last Post: 05-28-2010, 11:31 PM
  4. Need Help! 2.4 Stator holder ring broke...and other questions...
    By silverbullet02 in forum Technical Discussion
    Last Post: 06-24-2007, 12:23 AM
