Results 1 to 8 of 8
Thread: Gelcoated Fiberglass panels
07-27-2016, 03:51 PM #1
Anyone have a source to buy panels in different thickness? Either gelcoated or possibly nonskid finished.
07-27-2016, 06:15 PM #2
Nidacore (now CarbonCore) gelcoated panels: http://www.carbon-core.com/panels-composite.htm
07-27-2016, 09:00 PM #3
,What will the panels be used for ?? What sort of thickness you wanting and what size need more info Please !!
07-28-2016, 12:30 PM #4> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
07-28-2016, 06:09 PM #5
First need to know what they are to be used for and they definitely need to have a gel coated finish or you will have problems with fibers on the surface pattern as well as slinters , Colour is important if its for outside use ANY dark colour draws heat and if you have children will burn the souls off there feet .
07-31-2016, 08:40 AM #6
we cant help if theres no reply to questions asked !!
07-31-2016, 10:21 AM #7
Whoaa Relax.....
I have a center console that is mint but the coring is obviously soft under the deck around the console where you stand I need a piece of gelcoated glass to laminate over the existing floor to have a finished product when its done at least 4'x8' x at least 1/4" thick or opinions on thickness.
I did find a company in ga that can make panels smooth and non skid in any size
07-31-2016, 04:50 PM #8
That's what we wanted to know ! Now you can get some help from everyone
On a personal note photos would be a big help also to see what you have and how big etc !
Plus if the floor is soft around the center console then it needs chopping out and replacing not covering up. The floor will have a core for sure and that's what's separated, typical !.
All and any walking surfaces need good glass each side of a 18mm or 20 mm thick core and id suggest Balsa wood not foam . Once foam comes loose it just keep falling apart and you get what you got !
If you deck has a tread pattern if you cut it carefully and neatly you might be able to re-core and re-glass it and fit in back in the hole it can out ofLast edited by tunnels; 07-31-2016 at 06:35 PM.
Where to buy composite panels in so cal.?
By GETBOATS in forum Fiberglass and Composites DiscussionReplies: 8Last Post: 09-18-2012, 04:58 PM -
Are fiberglass panels available pre gelcoated?
By 2.5-21 in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 02-27-2012, 07:27 PM -
Dash Panels
By WSJR1 in forum General Boating DiscussionReplies: 0Last Post: 06-18-2010, 01:01 PM
