Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 90
  1. #46
    The problem with the run on the stand or ear muffs is until you put them in the water with a gear case and prop, in gear under load, then is when you find out the bores are all tapered and it doesn't run worth a can of beans.
  2. #47
    Jul 2016
    Massachusetts
    But i did do a compression test......
  3. #48
    Jul 2016
    Massachusetts
    Quote Originally Posted by Mark75H View Post
    Just means you need props with an inch or two more pitch
    I can live with that. Hears hoping that is all it takes.
  4. #49
    Jul 2016
    Massachusetts
    Quote Originally Posted by Karsten View Post
    Well, I have another one that needs work if you need another project...1984 1150 IL6.
    Awesome what you have accomplished......I know nothing about them.
    Karsten
    I've been known to travel some for a good deal...but Utah?? The mrs. Would not approve.
  5. #50
    Aug 2015
    NE Tennessee
    Quote Originally Posted by Stevewatr View Post
    Unless you made a vacation out of it and take the whole family to see the grand canyon.
  6. #51
    Aug 2015
    NE Tennessee
    Actually the compression testing is just a preliminary test, should be followed up by a leak down test. The two go hand in hand.
    As a side note, you will get a better picture of the leak down test if you do it an inch or less from TDC. You'll have to hold the flywheel steady as the compressed air used will try and push the piston down.
    Idea being to get the rings out of the top part of ring travel.
    jmho
    James
    Last edited by W2F a V-King; 10-02-2016 at 09:28 AM. Reason: added a second thought
  7. #52
    Jul 2016
    Massachusetts
    I agree with assesment that a leak down test would provide a clearer picture of motor condition. But since i already bought the gear case, I'll skip that tedt and proceed directly to the "blow it up on the water" test.
  8. Likes Mark75H, milkdud liked this post
  9. #53
    Jun 2009
    Middle USA
    I bet you will like the 2.3 gear ratio better anyway. Nice looking lower unit and hamburger. I could use both. I did the math backwards. Going from 1.78 to 2.3 means your 15 pitch prop will need to be 19p now to turn the same RPM and speed. Find a 19p.
    Good luck to you.
    L6fan57-88
  10. Thanks Stevewatr thanked for this post
    Likes Mark75H liked this post
  11. #54
    Jul 2016
    Massachusetts
    Quote Originally Posted by milkdud View Post
    Good luck to you.
    Thanks!
  12. #55
    Jul 2016
    Massachusetts
    Been a little while since I posted anything about this motor. In this video I decide to examine the condition of the pump impeller on my replacement gear case. Sure am glad I did! Looks like the last person in there installed the impeller housing improperly. I wonder if that's why the guy I got it from said it came of a junk powerhead?
  13. Likes Mark75H liked this post
  14. #56
    Jul 2016
    Massachusetts
    Part 51 is up!
  15. #57
    Aug 2015
    Chesapeake, Va
    i love your project on the [ tower of power ] , did it run ?
  16. #58
    Jul 2016
    Massachusetts
    Quote Originally Posted by merc old school View Post
    I haven't tried it since installing the gearcase. Im hoping to try this weekend.
    Steve
  17. Likes Mark75H liked this post
  18. #59
    Jul 2016
    Massachusetts
    Well winter has arrived in New England, so testing out the Tower of Power on the water will have to wait. This will be the last video for a little while.
    In other news, I was recently given to Suzuki DT150's that need work. Should make for an interesting project down the road.
  19. #60
    Rhode Island
    Winter is definitely here in New England... -4 farenheit with the windchill haha.
  1. 1972? Sidewinder Sport Boat with Tower of Power $3995
    By lewolson in forum Hulls up to 20'
    Last Post: 06-21-2014, 08:34 AM
  2. basket case
    By greg88 in forum Technical Discussion
    Last Post: 03-13-2010, 11:17 PM
  3. Latest basket case.
    By Cobra1racer in forum Technical Discussion
    Last Post: 02-15-2008, 07:34 PM
  4. 1970 1350 vs 1972 1150
    By Tom Smyth in forum Technical Discussion
    Last Post: 01-17-2007, 06:42 PM
