Results 1 to 6 of 6
07-26-2016, 06:39 PM #1Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1266
- 368
Rumble sound coming from the front of the i/o shaft
Got the body work done still to find where the water is coming in started it and it makes a rumbling sound around the shaft and it sound like something rubbing gimble bearing? Leak is coming in the slot under where the shaft comes in. Any ideas or where to start by the way the donzi is for sale a 1966 16. thanks Rick
07-26-2016, 09:40 PM #25000 RPM
- Dec 2012
- Moses Lake, Wa.
- 156
Gimble bearing, possible u-joints. Pull OD. and look/touch. Leak is probably shift cable bellows. Stand at right side of outdrive with drive tilted up. Push OD away to the port side. Look and feel the small bellows @ the shift cable. I would think the bellows has a hole and/or ripped/torn. Direct shot into the boat for water.
07-27-2016, 05:51 AM #3Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1266
- 368
Thank you I am sure you are right.
07-27-2016, 12:47 PM #4
If the driveshaft bellows is leaking could make the u joints and gimbal bearing rusty and making noise and water could be leaking into boat if the seal behind the gimbal bearing is bad?
07-27-2016, 02:18 PM #5Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1266
- 368
How do you replace that seal and check it. thanks Rick
07-27-2016, 03:52 PM #6The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...Always try to refrain from tilting the drive all the way up, with the gearshift in forward & running the boat, even on the trailer. The cross bearings(u-joints) can cut the main large rubber bellows, & then leak. This goes for the Alpha's & the Bravo's. Any drive that shifts in the drive itself, as the input shaft & u-joints are always spinning, even while in neutral & running.
delawarerick thanked for this post
growling sound coming from berkley 12je jet??
By navyman_98_99 in forum Jet Boats, V-Drives and Stern DrivesReplies: 1Last Post: 03-17-2008, 02:18 PM -
Who's Coming To This Rumble And Also Been To The First Three???
By Instigator in forum General Boating DiscussionReplies: 10Last Post: 08-04-2004, 12:04 PM -
Rumble Who's coming with what?
By cs1 in forum General Boating DiscussionReplies: 42Last Post: 08-03-2004, 08:48 AM -
Bud Girls Coming To The Rumble!!
By Instigator in forum General Boating DiscussionReplies: 50Last Post: 04-01-2003, 10:03 PM -
BOATNIK COMING TO THE RUMBLE!!
By Instigator in forum General Boating DiscussionReplies: 0Last Post: 07-30-2001, 09:31 AM
