Results 1 to 9 of 9
Thread: Portable Tach Question
07-25-2016, 07:32 PM #15000 RPM
- May 2001
- Maine
- 983
- 35
- 42
- 171
I am installing one of those small tach's on my 225 Sport XS (2 stroke) to record operational hours. It has a wire that you wrap around one of the plug wires. Where the motor is a 6 cylinder I have a choice of several modes...
1. 1P1R= 1 SPARK PER 1 REV
2. 2P1R= 2 SPARK PER 1 REV
3. 3P1R= 3 SPARK PER 1 REV
4. 4P1R= 4 SPARK PER 1 REV
5. 6P1R= 6 SPARK PER 1 REV
6. 3P2R= 3 SPARK PER 2 REV
7. 5P2R= 5 SPARK PER 2 REV
8. 1P2R= 1 SPARK PER 2 REV
I am guessing either the 6P1R or the 1P2R... thoughts?Last edited by 4Speed; 07-25-2016 at 07:38 PM.
07-25-2016, 08:25 PM #2
i installed a "Motominder" on my 260 at the last rebuild,dirt bike digital clock. wrapped the signal wire on #4 spark plug wire, double face taped it to the port side of the block, been there for 5 years. works great to log running hours, it was $35. bad thing is that i seem to put only 10 hours per year as it turned 50 total hours on the last outing !
LTB OLDGUY
07-25-2016, 09:05 PM #35000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
the plug wire that your monitering only sparks 1 time per rev. your not counting all plug wires just that one. #1 is the choise -th
TuffyD thanked for this postDavid - WI liked this post
07-26-2016, 05:24 AM #45000 RPM
- May 2001
- Maine
- 983
- 35
- 42
- 171
Are you saying, where its a 2 stroke it would be 1P1R?
07-26-2016, 06:26 AM #5
can read from any cylinder,my setup just monitors running time only, not a tach.
LTB OLDGUY
07-26-2016, 10:15 AM #65000 RPM
- Dec 2012
- tn
- 686
- 17
- 46
If you get it to work - let me know how- I got one in a drawer I never did get to work-
07-26-2016, 10:35 AM #7
07-26-2016, 10:39 AM #8
Yes 1P1R, but i had one like that and had problems also, bought the tiny tach for 2 stroke only and works fine.
07-26-2016, 05:08 PM #95000 RPM
- May 2001
- Maine
- 983
- 35
- 42
- 171
I purchased it for the hour meter but figured I might just as well see if rpm recall will work... it was set on 6P1R and the highest RPM after checking it was 1800... No way on a STV at 90+ MPH so I figured something was set incorrectly.
Tach question
By outasite in forum Technical DiscussionReplies: 1Last Post: 07-02-2016, 06:48 PM -
Tach question
By BajaSvr in forum Technical DiscussionReplies: 3Last Post: 07-11-2012, 08:30 PM -
Merc tach question,and charging question
By hydroguy21 in forum Electronics, Audio Systems, and WiringReplies: 0Last Post: 07-24-2011, 04:56 AM -
Tach Question
By vector mike in forum Technical DiscussionReplies: 5Last Post: 03-26-2003, 03:32 PM
