Results 1 to 4 of 4
Thread: 2005 Mercury Verado 225 smoking
07-19-2016, 06:57 PM #1New Member
- Jan 2015
- Gallant in TN
Have twin merc 225 verado's on a 30' Concept CC with approx 500 hrs, port engine began smoking, no codes, didn't feel like it lost power, etc., pull plugs find oil in # 5 and #6, do a compression test all cylinders approx 125, took to local dealer, they check supercharger and say checked good, did a leak down and tested good........ Week later mechanic says #5 and #6 oil seals bad and wants to replace the powerhead, tell them to button it up and will come pick it up, not very confident in our local service departments on these so trying to get opinions and info if anyone else has had a similar problem or areas to check. Thanks in advance for any input.
07-20-2016, 04:50 AM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Sounds weird that it passed a leakdown with leaky oil seals on the valves? Not a verado user, but that makes me suspicious.
07-20-2016, 03:41 PM #3
its the plug O rings between the cavity for the plugs and the valve cover, just do a Gasket set and to do Valve seals Cams have to be removed, ive seen it on an 04 i service, it comes from the thread side of the plug around the spark plug itself, unless it smokes heavily then you may need guides but at 500 HRS the guides shouldnt show that much wear... whats the oil level, and how long since last oil change... after making QUARTS of oil i switched engine oils to Certified Labs Full Synthetic and that problem stopped
07-22-2016, 12:27 PM #4
Check out this site. Lots of verado gurus on there. http://www.veradoclub.com/
2017 30 Concept, 2006 30 Superboat (Sold), 1998 24 Superboat (Sold)
Mercury Tech: failed oil injector line for 2005 Mercury 175 (2005) eng
By riverpro2012 in forum Technical DiscussionReplies: 6Last Post: 07-20-2016, 03:53 PM -
2005 Mercury Verado Lower Unit Housing
By MacGyverJB in forum Lower UnitsReplies: 1Last Post: 03-04-2015, 10:12 PM -
2005 Verado 250
By TTodd in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 0Last Post: 10-30-2014, 09:10 PM -
Mercury 300 Verado
By Batboat22 in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 8Last Post: 08-25-2007, 04:56 PM -
Mercury Marine and Mercury Racing Product Report: 300 Verado, 200 I-4 Verado, 1200SCi
By Scream And Fly in forum General Boating DiscussionReplies: 68Last Post: 02-21-2007, 07:56 AM
