Page 3 of 3 FirstFirst 1 2 3
Results 31 to 33 of 33
  1. #31
    Sep 2006
    Guy up here in Canada sells an apparatus that is an inch wide piece of tubing(inner size big enough to slide over ball mount and then a piece welded on the bottom to form an L that has a 1/2 nut weld over a slightly larger hole. When a bolt is put into the nut it tightens down on the receiver and binds the ball mount firmly. I use them. Quits everything down.
  2. #32
    Sep 2012
    Pennsylvania
    Could we see a picture of one ?
  3. #33
    Sep 2006
ID:	352408Click image for larger version.
ID:	352409Click image for larger version.
    Len's Enterprise Thoral Ontario. Not me
  4. Thanks Steve-S thanked for this post
  1. Weight distribution in vintage tunnel hull
    By SJC in forum Props, Setup, and Rigging
    Last Post: 01-14-2015, 12:46 PM
  2. Weight distribution on a Tunnel...(found nothing with search)
    By pwerwagn in forum Props, Setup, and Rigging
    Last Post: 11-02-2007, 08:29 AM
  3. 1989 charger Tunnel V Hull Weight??
    By dreamer52 in forum Technical Discussion
    Last Post: 06-27-2006, 02:41 PM
  4. Shadow Tunnel Boat Weight
    By bob richling in forum Technical Discussion
    Last Post: 01-28-2004, 09:36 PM
