Results 1 to 15 of 33
07-14-2016, 11:33 AM #1Member
- May 2009
- Orange
- 66
Negative Tongue Weight on a 19' Tunnel
Hey guys,
looking for some suggestions on how to add some tongue weight to my trailer. I've got a 19' Bahner tunnel sitting on a tandem axle Hensley Gunter Trailer. The problem is instead of having tongue weight i almost have negative tongue weight because it is an outboard with a setback jack plate there is too much weight behind the axles and the tongue can be lifted with one hand and when the motor is trimmed up the tongue will actually float level without dropping to the ground. So while trailering it bounces up and down a lot and you can hear the slack of the hitch in the receiver slapping around. Because it is a tunnel and sits low and close to the trailer some options are out such as mounting the spare tire up front and I do not want to the move the boat further up on the trailer leaving the skids exposed in the back and making it more difficult to tie down. The axles cannot be moved back any further than they already are either. Any suggestions would be appreciative.
07-14-2016, 11:57 AM #2
Post a handful of pics
Azure AZ259, 8.1
07-14-2016, 12:10 PM #3Member
- May 2009
- Orange
- 66
searching my phone now if i have any. I will have to take some when I get home tonight.
07-14-2016, 12:39 PM #4Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,737
- 102
- 115
- 1556
- 514
Can you move the Axle?
God, Country, and Fast Boats
07-14-2016, 12:41 PM #5
Is the trailer tongue "level" with the ground when it's hooked to your tow vehicle?
07-14-2016, 01:21 PM #6Member
- May 2009
- Orange
- 66
yes its level that is the first thing i checked. I have read that if you drop it lower it will add tongue weight but i would prefer that it trailers level not at a downward position and unfortunately the axles cannot be moved back further. That was the first thing I checked.
07-14-2016, 02:54 PM #7
try to move the boat forward on the trailer
TRANSPORT SERVICE...UP TO 33 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY
LIVE LIFE ON THE EDGE,LESS CROWED BETTER VIEW
07-14-2016, 05:47 PM #85000 RPM
- Sep 2012
- Pennsylvania
- 142
- 28
- 22
- 50
What about removing the front axle ?
You could run different height tires , 205 front/ 255 rear ....Last edited by Steve-S; 07-14-2016 at 05:54 PM.
07-14-2016, 05:51 PM #9Member
- May 2009
- Orange
- 66
Tried that once. It definitely helped but was a pain in the butt to get in and out because they had to be all the way up under the bow. looking for something more permanent or at least easily removable
07-14-2016, 07:15 PM #10Scream And Fly VIP
- Jul 2013
- California
- 1,556
- 21
- 62
- 83
- 293
Not many choices. Move the axles back or move the boat forward. If you could ever find it you could bolt some lead on the tongue. Second option would be some heavy steel plates on the tongue. Sounds like you need about 80 to 100 lbs.
07-14-2016, 07:26 PM #11
Post pics of the trailers suspension
Azure AZ259, 8.1
07-14-2016, 07:29 PM #12
Sometimes you can adjust the leafs to change the load.
You can add longer shackles to the rear axle leafs to reduce load on the front.Azure AZ259, 8.1
07-15-2016, 08:11 AM #13Member
- Mar 2006
- Boynton Beach, FL
- 74
- 13
- 18
I would mount a locking toolbox or a spare tire or two up there. Load the tongue down.
Beer will not solve all of your problems... but neither will milk!
2005 Lightning 18' Action - 150 Optimax - SOLD
1982 Eliminator Daytona 23' - Twin 260's - SOLD
2012 Concept 32FE - Twin 300 Verados
07-15-2016, 04:38 PM #145000 RPM
- Apr 2011
- Long Beach
- 319
- 7
- 14
I have the same problem with the same boat, but a single axle trailer. I need to move the axle back, but in the mean time I just throw a couple of 5 gallon water jugs (blue gas cans) under the deck for towing. It seems to work.
07-15-2016, 04:47 PM #15Member
- May 2009
- Orange
- 66
Your hull is exactly the same as mine except for the protrusion in the back of yours has been removed. But between that and the setback jackplate is what causes it. Is your trailer a Hensley Gunter? It would be much better if it was a single axle. That is why most Bass boats are but Bahner built mainly Jet boats, the way this trailer is set up it really seems its meant for a tunnel jet built by bahner.
Weight distribution in vintage tunnel hull
By SJC in forum Props, Setup, and RiggingReplies: 2Last Post: 01-14-2015, 12:46 PM -
Weight distribution on a Tunnel...(found nothing with search)
By pwerwagn in forum Props, Setup, and RiggingReplies: 7Last Post: 11-02-2007, 08:29 AM -
1989 charger Tunnel V Hull Weight??
By dreamer52 in forum Technical DiscussionReplies: 21Last Post: 06-27-2006, 02:41 PM -
Shadow Tunnel Boat Weight
By bob richling in forum Technical DiscussionReplies: 7Last Post: 01-28-2004, 09:36 PM
