Results 46 to 58 of 58
Thread: Looper primary compression
01-16-2017, 01:04 AM #46
01-16-2017, 07:00 PM #47Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
you could make a set of offset heads if you have a mill and lathe, use the 2.7 chamber as a model and machine the 3.0 heads to fit them?
03-24-2017, 02:17 PM #48
Here you have some pics of the reassembled, stuffed looper intake. Now it will lay soaked with fuel for a couple of days, just to make sure that the white filler stuff will stay intact. The can says that it can handle gasoline, but better safe than sorry...
Different colours - differnt thickness
From the inside, not much dead space left... The lower side of the reed blocks has got stuffers aswell, just didn't have a good picture.
Anyone who can tell me where the long hose is supposed to be attached? (1998/99 225hp Ocean runner)Last edited by Captain75; 03-24-2017 at 02:20 PM.
03-24-2017, 03:25 PM #49
03-24-2017, 07:19 PM #50Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
top main if that comes from the bottom main
needs to have a working one way valve
03-25-2017, 05:58 AM #51
Its not the same hose. The one connecting the lower and upper main is visible below the long hose in the picture. Only a short piece of hose that normally attaches to the oneway valve, is visible.
03-25-2017, 06:53 AM #52
By stuffing the reed housing exactly what gain will you get ? I am curious to what this does.
will this alone give a noticeable effect on power at a certain point ? or all over power ?
and can this be done to most motors ?
03-25-2017, 10:35 AM #53Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
That is a vent hose to top of new style air box. You need to make sure the vent from top bearing to intake valve is open or you will have upper main issues.
06-09-2017, 01:05 PM #54
Hello guys! Its been a while since I posted on this board, this has been due to heavy work load However, last weekend I managed to get our boat into the lake and I must say, the stuffing described with pics in this thread made a huge seat of pants difference, biggest one since I added finger ports. Holy ****, boat takes off like a rocket! If you haven't done any stuffing, I would really recommend you to do this! Its cheap, safe and you will get a snappy motor!
Best regards!
Anders
06-09-2017, 01:53 PM #55Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Did you post pics of the finger ports? Home much compression did that cut yield? Big gains, super !
06-09-2017, 02:25 PM #56
06-09-2017, 03:05 PM #57Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I wonder if the stuffing just put back what the finger ports and holes in the piston took out?
That would be an interesting calculation
06-09-2017, 03:16 PM #58
compression on 87 200 looper
By RUDE Attitude in forum Technical DiscussionReplies: 4Last Post: 06-20-2007, 01:06 PM -
v4 looper compression help
By oldschoolltv in forum Technical DiscussionReplies: 8Last Post: 08-09-2004, 10:00 AM -
looper compression
By j2somthin in forum Technical DiscussionReplies: 1Last Post: 02-28-2002, 07:01 PM -
OMC Looper Compression
By DSP1 in forum Technical DiscussionReplies: 3Last Post: 02-27-2002, 02:52 AM -
Primary Compression - or whatever it's called
By MadMat in forum Technical DiscussionReplies: 12Last Post: 11-15-2001, 04:09 AM
