Results 1 to 7 of 7
    Jul 2016
    Rhode island
    Exclamation I have a question about my 87 hydrostream valero yt hull shape !!!!!
    So I am currently in the recore process on my valero yt and I'm not sure if the hull is supposed to have these longitudal curves in the bottom of the boat or if the core is so bad that the hull is bending on the trailer. If that is the case then I just need to get it off the trailer and build a cradle for it to straighten it out before putting new core in. If it is supposed to be curved in those to spots then I will recore as is. Desperately looking for someone with knowledge of the valero yt hull shape. It was difficult to get a good picture of the spot that I am talking about but if you look at the support for the bunks of the trailer that's where I think it is flexing
ID:	348413   Click image for larger version.
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    Quote Originally Posted by Fatbottedgirl View Post
    To do a re-core the boat should not be on a trailer any way !
    I THINK I saw what you talking about trailers do more long term damage to hull bottoms that any thing else .
    It will possibly be more obvious once you get it off the trailer if the shape is meant to be there or not. The shape should also be obvious Inside the hull as well . If it looks strange it will be !
    What's the core like inside the hull ? rotten ??and what thickness? what glass is there over the top of the core ??
    Need to post lots photos with lots of detail is a great help to answering your questions
    Jul 2007
    so is the boat off the trailer ?? what did you find ?? like I suggested have a look inside the hull and use a straightedge !or a fairing batten and that will give you a good idea what's there
    Jul 2016
    Rhode island
    I found someone with the same boat and the bottom is straight, currently working on a way to get it off the trailer and get it back into shape
    Jul 2007
    AND while its off the trailer a way to redo the bunks so they are the right shape and it wont happen again !
    Like I said trailers do more damage that most other things specially rollers as the localized point loading it very high and boats spend a lot of time just sitting and if the are stored outside and get filled with rain water that's even worse .
    Have fun !!
    Mar 2010
    Brigham City, Utah
    I would say you are in need of some new bunks. The metal bunk support is what is holding the hull up and not the complete length of the bunk.
    Karsten
    Jul 2007
    Quote Originally Posted by Karsten View Post
    Karsten
    photos are best way to describe so everyone can SEE what you are talking about .
  8. Thanks Timothy Hoffman thanked for this post
    Likes Timothy Hoffman liked this post
  1. 1989 Hydrostream Valero YT/175 Mercury Nice Shape - $8000
    By sprint17 in forum Hulls up to 20'
    Last Post: 04-26-2016, 10:07 AM
  2. Hydrostream AT hull question,
    By Varmint in forum Fiberglass and Composites Discussion
    Last Post: 07-16-2015, 04:57 PM
  3. Hydrostream Valero (canuck edition) hull repair!!!
    By huck_this in forum Fiberglass and Composites Discussion
    Last Post: 06-25-2009, 08:00 AM
  4. question about valero yt hull integrity
    By illMATTic in forum Technical Discussion
    Last Post: 03-03-2006, 07:41 PM
Bob's Machine
