Results 1 to 15 of 48
07-06-2016, 11:45 AM #1
SOLD - Pair of 380hp Monty Racing V8's, 25" offshore mids w/CLE lowers
SOLD!
For sale is a pair of Monty Racing built V8's on Evolution Marine custom 25" offshore midsections with Mercury 4-hole CLE counter rotating lowers. Fresh water use ONLY!
Motor specifics:
- Both motors started out as 4.0l blocks, were bored .020" over and had new Wiseco forged pistons installed.
- Monty Racing performed his MOD I level port work magic with finger ports (see his website for info and costs http://montyracing.com/html/price.html)
- Both motors run stock air box with mid-bore carbs and large (3-screw) throttle plates. VRO pumps have been removed (premix only).
- Hand lapped reed cages with Boyesen reeds.
- Port motor has stock 6700rpm powerpack, but starboard motor has CDI 8500rpm powerpack.
- Port motor dynoed 381hp/339tq, starboard motor dynoed 383hp/340tq.
- Evolution Marine lightweight fiberglass lift off cowls with Johnson Offshore 1 decal set. These have a few small spider cracks here and there from age but are in really good shape. Very light for the size.
- Starboard motor looks to have a water leak from the gasket under the regulator/rectifier. There is slight water evidence on the back of the block.
- Starboard motor had a crack in the water jacket on the rear of the block which was welded years ago. No leaks now. This is in a non-structural area of the block.
These motors have roughly 200-225 hours on them. Ran a compression check the morning of July 6, 2016 in Las Vegas at 2100' above sea level, cold, throttles closed. Port battery might not have been fully up, but you can see the spread. UPDATE: I will be re-running the compression numbers where the motors are in FL soon to update withe a fresh battery and near sea level air pressure.
Results:
Port: Star: 1:133# 1:149# 2:135# 2:143# 3:132# 3:148# 4:136# 4:144# 5:131# 5:148# 6:130# 6:145# 7:130# 7:148# 8:127# 8:143#
Midsections:
- Originally built by Evolution Marine
- 25" with custom grafted offshore snouts
- Dry stacked, with rear water outlets.
- Exhaust adapters have been drilled for additional water inlet. These can be easily plugged. Currently, I have a Jabsco water pump in the boat that pumps water to each mid using 3/4" hose to supplement the CLE water pumps, which are lower volume than the original V8 pumps. This has a one-way valve that prevents WP pressure from going out the adapter. This is helpful at idle to keep the motors fully cooled.
- Starboard motor trim has a leak on the left low speed trim ram seal.
- The white stuff on the mids is just hard water. Needs a good cleaning with some CLR and will look like new.
Lowers:
- 4-hole CLE's with custom adapter plates.
- Fresh Merc hi-perf gear lube ~5hrs ago (April, 2016).
- New water pumps, April 2016
- LH is straight skeg, 1.87 ratio, small shaft.
- RH is swept skeg, 1.87 ratio, small shaft.
- Custom shifter linkages use modified Mercury shift shafts (push/pull to rotate).
- RH case had a crack to the left of the pinion where a broken pinion cracked the case years ago. This was welded, then JB welded inside and out and does NOT leak.
Motors are currently in Port St Lucie, FL. $10,000 for the pair, plus shipping/crate. $5,000 each, if the left goes first. If you buy the pair, I will include the steering rams, wing plates and tie bar! Would prefer a local pickup. Would entertain Merc 2.5 15" factory offshore midsection on partial trade. Questions? Email Keith@stvboats.com or call 702-324-4449.Last edited by STV_Keith; 12-12-2018 at 06:56 PM.
Keith-
Smoking Joe liked this post
07-06-2016, 03:37 PM #2
Great advertisement Keith, only wish I was in the market. Good luck with your sale.
Wellcraft Nova 230 XL, 300hp Johnson.
Seahawk 45 Sport Fisher, twin 306hp Volvo.
Steadcraft 28, Yanmar 300hp. Sold.
Markline 800, Volvo 300hp. Sold.
Haines Hunter V19, Volvo 170. Sold.
16ft 6in Figlass Sidewinder, 140 Suzuki. Sold.
John Rork liked this post
07-09-2016, 01:45 PM #3Member
- Jan 2005
- Montreal Quebec
- 44
Wow Nice motor! Repower with what kind ?
07-16-2016, 12:34 PM #46000 RPM
- May 2006
- SUNRISE FLA
- 1,854
- 11
- 160
- 4 Thread(s)
Keith givem 2 your brother or dad wont go 2 waste there.red rocket out
07-22-2016, 11:15 AM #5
Haha, good idea Warren!
Bump...Keith-
08-08-2016, 11:29 AM #6
Kieth,
What high speed jets are you running in these? Also, late model or earlier carbs?
Thanks!
08-08-2016, 11:54 AM #7
I don't have the answer to either question. Same jets have been in the same carbs for 8 years and I've never looked. PM me if there is a simple way to identify "late or early" mid bore carbs.
Keith-
08-13-2016, 06:16 PM #8Junior Member
- Jan 2015
- grand bahama bahamas
- 9
those are nice. any idea where i can find one of those lower units for omc v8? i have one myself
08-15-2016, 12:57 PM #9
It's a Mercury CLE lower with an adapter plate and custom shift rod linkage. R&R Prop Shop made the billet adapter plate (702-564-7502). Look for CLE's or sportmasters here in the classifieds.
Keith-
Mr242BAHAMAS thanked for this post
08-19-2016, 09:07 PM #10
really nice motors Keith...good luck with the sale!
08-20-2016, 05:12 PM #11Junior Member
- Jan 2015
- 9
greatly appreciate the info good luck with your sale
08-31-2016, 12:05 PM #12
Wow, surprised to see you're selling them. I actually came on here to put mine up for sale and see how much they sell for. Wifey wants new 4 strokes.....
if if anybody wants 5 of these engines, I have another three for sale......True Viking
Scarab 34 SS with Triple OMC 4.0 V8's
09-20-2016, 06:30 PM #13
Hey Keith,
you think the wife would notice if I put both of them on the back of my deck boat? Lol
STV_Keith thanked for this post
09-20-2016, 07:25 PM #14
Probably just the noise...dry stacked twins have their own sound.
Keith-
10-04-2016, 11:52 AM #15
Boat is all cleaned up from the tow back to FL and has even been water tested in that "magic water" you guys have back East. Boat went "deep into the 70's" and turned both motors 6700...definitely running strong. Who needs some big power for themselves?
Keith-
