Results 1 to 6 of 6
Thread: Lightning Gearcase L1 vs L2
06-30-2016, 12:24 AM #1Member
- Jun 2012
- Canada
- 84
Starting a new thread on this. I had started asking some questions in a thread pennman had started in the marketplace. Out of respect to him, rather than litter his thread with more of my questions, I created a new one after some searches came up fruitless.
I'm asking because I had piled up the gearcase on my 96 V6 looper. I picked up a Lightning L1 with very low hours (less than 10) for an ok price.
I thought the L2 had problems and had been recalled and replaced by the M2?
Did the L1 suffer the same early expiry date issues? Is the L1 stronger than the 96 gearcase I originally had?
Now that I have an L1, is there a trick to making it last? I plan on getting the carrier pinned, anything else?
06-30-2016, 06:49 AM #2Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
L1 is basically the same internally as your 96 with the possible exception of the pinion bearing retainer (changed right around that time), they went back to the original design. L2 has bigger bearings which in turn requires different gears which have the same gear pattern, it also pick up more water. Durability seems to be related to the boat used on and set up, IMO they last much better on boats that don't need positive trim to run. The magnum (M2/SLE) replaced the L2 in production and if the L2 failed in the field it was the replacement unit as it is stronger (bigger) but at a cost of about 3MPH.
Scream And Fly liked this post
06-30-2016, 07:05 AM #3Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
06-30-2016, 05:36 PM #4Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Don't recall exactly but the 250Ho started coming with the SLE in about late 09
06-30-2016, 06:59 PM #5Member
- Jun 2012
- Canada
- 84
So is it true the L2 is stronger than the L1?
What can be done to make the L1 last?
07-01-2016, 08:14 PM #6Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Yes a little bit. Blue printing the gears helps, proper set up and yes break in.
OMC Tech: Difference magnum vs lightning gearcase
By CALVIN in forum Technical DiscussionReplies: 3Last Post: 09-17-2013, 05:47 AM -
lightning gearcase on 91 omc
By superryan in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 8Last Post: 05-01-2013, 11:36 PM -
ETEC Lightning gearcase?
By mxz in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 9Last Post: 08-25-2010, 11:48 PM
