Results 1 to 15 of 73
Thread: 1991 mercury 2.5l efi
06-29-2016, 02:20 PM #1Member
- Jun 2016
- Michigan
- 54
I just got this motor and it won't start I am not getting any fuel to the filter just before the fuel rail anyone have any suggestions on what I need to do for this? I am not familiar with this type engine I am mechanically inclined but I have no book or anything on this. Thanks
06-29-2016, 02:36 PM #2Member
- Jun 2016
- Michigan
- 54
Anyone know where the fuel pump is on this motor it is on a laser 388 le I don't here is fire up when I turn the key on. Also what pump should I replace it with
06-29-2016, 02:58 PM #35000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Make sure your tether is on, my pump doesn't come on on less tether is hooked up. What model 2.5?
06-29-2016, 03:25 PM #4Member
- Jun 2016
- Michigan
- 54
Mercury 2.5l efi. What tether and where is it at
06-29-2016, 03:27 PM #5Member
- Jun 2016
- Michigan
- 54
What do you mean which model? I only see the 2.5l efi is there something else I should see serial number is 0d110626 if that helps
06-29-2016, 03:56 PM #65000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Need to know if a Laser or horn setup. Safety kill switch tether.
06-29-2016, 03:59 PM #7Member
- Jun 2016
- Michigan
- 54
It is a laser 388 le I don't see a switch like that anywhere where should it be located
06-29-2016, 04:25 PM #8
send me an email address and i'll send ya a manual in pdf.....
06-29-2016, 04:27 PM #9Member
- Jun 2016
- Michigan
- 54
Trikmit@hotmail.com. Thank you
06-29-2016, 04:30 PM #10
be patience.. it takes a few minutes ta open....
that serial number shows ta be a 2.5 "hot rod" horn motor originally!... so its no tellin' what ya got... pictures will help.Last edited by tlwjkw; 06-29-2016 at 04:39 PM.
06-29-2016, 04:51 PM #11Member
- Jun 2016
- Michigan
- 54
I will take some and send to your email if that's ok
06-29-2016, 04:53 PM #12
sure...
06-29-2016, 07:08 PM #13
early 260 hot rod... forget that manual i sent ya.. sorry, don't have hi perf. manual on pdf.
you NEED TO FIND SOMEONE in your neck of tha woods to show ya tha ropes on that motor, especially being so green..... its NOT A NORMAL motor.... you, at tha very least, need a manual for it BEFORE attempting ta do anything to it..............jmo
06-29-2016, 08:09 PM #14Member
- Jun 2016
- Michigan
- 54
I ordered one and I have tried to find someone but no luck yet. Anyone in detroit mi area know about this motor that can help me out.
06-29-2016, 08:10 PM #15Member
- Jun 2016
- Michigan
- 54
Do you know about what hp it puts out? Do you know where the fuel pump is?
1990 MERCURY 200 or 1991 ???
By Christopher Willis in forum Technical DiscussionReplies: 8Last Post: 06-29-2016, 03:57 PM -
1991 mercury 175 xri
By clayton bigsby in forum Technical DiscussionReplies: 2Last Post: 03-17-2015, 12:29 AM -
OMC Tech: 1991 175 Silverstar Eagle vs. 1991 175 Intruder & FastStrike
By skimmabird in forum Technical DiscussionReplies: 6Last Post: 03-13-2014, 07:57 PM -
Mercury Tech: 1991 Mercury 2.5 EFI
By Matts94z28 in forum Technical DiscussionReplies: 4Last Post: 05-10-2013, 07:34 AM -
Mercury Tech: 1991 mercury blues
By rex cunningham in forum Technical DiscussionReplies: 7Last Post: 04-17-2009, 11:32 AM
