Results 1 to 10 of 10
06-28-2016, 03:52 AM #1Junior Member
- Jun 2016
- inglis fl
1989 140 hp evinrude wont reach wot
I have a 1989 140 Evinrude that will only reach W OT if you take the airbox is off I know I can't run it this way and I'm at a loss as to what is going on with the airbox is off the motor spool up right to 6000 I have all new coils good Champion Spark Plug's there are new also timing is set to factory specs underload I've tried 1315 and 17 pitch props and nothing helps except taken off the air boxes I found out they have 50 intermediate jets and are supposed to be 54s I have the 54s on the way but in the meantime wanted to shake some brains and see if somebody could tell me what simple little thing I'm missing that's causing this problem thank you I didn't mention that there are two of them on the boat both have same problem
06-28-2016, 10:08 AM #2Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Did this just start? What size are the mains? Is the baffle in the air box? Timing linkage moving as it should?
06-28-2016, 11:03 AM #3Junior Member
- Jun 2016
- inglis fl
Mains are63 d timing linkage seems ok i bought the boat this way old owners said top speed was 25 mph and i knew that wasn't right . I did replace the vro fuel pumps with manual ones also i just know its something simple that im missing yes baffles are there
06-28-2016, 05:48 PM #4
try putting the airbox back on and running it with the cowling off...... maybe a bad powerhead gasket letting exhaust gasses in
06-28-2016, 06:40 PM #5Junior Member
- Jun 2016
- inglis fl
Ran them for a couple hours with cowlings on with no problems only time thers a problem is if the airboxes are on
06-28-2016, 06:41 PM #6Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Eating its own exhaust is possible but very rare on that engine. Dont run it without the airbox if you remove the cowl. 63D is the correct main jet, if carbs are not running over and the sync/link is good and it has spark on all 4 I would say you may have a weak stator. You need a peak reading meter to check.
savae123 thanked for this post
06-28-2016, 07:47 PM #7Member
- Apr 2009
- oregon
- 37
06-28-2016, 07:48 PM #8
what is the compression? Just asking
2008 Mirage V-Racer 1983 2.0L Mercury 15"
2010 Mirage V-Racer 1987 2.4 Original SST140 Powerhead
1974 Hydrostream Viper
1977 Hydrostream Viking
1995 Mirage River Racer " Boat On Loan" Thanks Mike Mullins 2.5 245hp 15"
savae123 liked this post
06-28-2016, 08:25 PM #9Junior Member
- Jun 2016
- inglis fl
Yes that's been checked n im running at sea level
06-28-2016, 08:28 PM #10Junior Member
- Jun 2016
- inglis fl
Racer i will get that checked next
OMC Tech: 1989 johnson 70 hp stopped running an cranks but wont start only backfires
By husseyford69 in forum Technical DiscussionReplies: 6Last Post: 08-17-2012, 04:27 PM -
Mercury Tech: 40hp 4 cylinder (1989) wont throttle up...?
By Bartman39 in forum Technical DiscussionReplies: 3Last Post: 09-26-2010, 09:59 PM -
1989 Evinrude 150 XP vs. 1986 Evinrude 150 Special Edition
By KOMotion in forum Technical DiscussionReplies: 10Last Post: 10-31-2009, 11:44 AM -
OMC Tech: Evinrude 225hp 89yr WONT SHUT OFF!!!
By piripi in forum Technical DiscussionReplies: 3Last Post: 09-01-2009, 07:33 AM -
Evinrude 6hp wont stay running Help!
By faster100 in forum Technical DiscussionReplies: 18Last Post: 03-13-2006, 05:23 PM
