Results 1 to 8 of 8
Thread: 1994 2.5 200HP Mercury EFI XR
06-25-2016, 01:54 PM #1Junior Member
- Mar 2016
- Sorrento, FL
- 7
Ok, I need some help. Here is the problem and what I have done so far.
Motor sat for 18 months and was not run. Took it out initially and it ran Ok but had a miss every so often. So I put the boat back on the trailer and took it home.
I then pulled the injectors and sent them off to have them cleaned. Changed the fuel filter and rebuilt the diafram fuel pump.
Motor would run on the hose but will not rev up under load.
Took the motor to have it diagnosed and they tested the stator and triggers and determined that one of the switchboxes was bad and so it was not firing on one bank.
I installed two new switchboxes (aftermarket parts not mercury) and it is still doing the same thing it will not rev up under load. I find it hard to believe that one of the new switchboxes is bad.
It acts like it is trying to run in some sort of limp mode. Is this possible?
Looking for some direction as to what to try next.
06-25-2016, 05:57 PM #2Junior Member
- Jul 2011
- huntsville, ontario
- 19
- 16
- 13
Did you clean the fuel filters on either side of the electric pump? There is one inside the fuel line between the VST and electric pump intake and one after the electric pump in the top hat looking thing. I had a similar problem on mine...1993 200 xri. Mine was the one before electric pump.
FL_Sanger_Barefooter liked this post
06-25-2016, 08:23 PM #3Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
are all the boxs still on it idel stabilizer, detonation controller, auto oiler still, and yes the one inside the u shaped hose at the bottom of the vst pump has caused many of headaches remove it dont replace it
06-25-2016, 08:28 PM #4Junior Member
- Mar 2016
- Sorrento, FL
- 7
Thanks for the idea. I have cleaned the one after the electric pump. I can't seem to screws out of the out of the one that is mounted to the bottom of the VST. I will have to try again tomorrow. Although I don't think it is lack of fuel. It wants to backfire if you hit the trottle hard without a load. That seems to indicate to me that some thing is out of time or it is not firing properly and allowing fuel to pass through to the exhaust.
I guess it is possible that one of the new switch boxes is bad but the odds of that seem very high.
06-25-2016, 08:31 PM #5Junior Member
- Mar 2016
- Sorrento, FL
- 7
06-25-2016, 09:05 PM #6Junior Member
- Jul 2011
- 19
- 16
- 13
Yup...in that u shaped hose. Take hose off and use a long 1/4" extension or piece of 1/4" od pex to push it out or check if its there. Push from the VST side of the hose. People trash them, people keep them. I kept mine - that fuel pump is plenty expensive!
FL_Sanger_Barefooter thanked for this post
06-25-2016, 09:16 PM #7Junior Member
- Mar 2016
- Sorrento, FL
- 7
Thanks. I will check that in the morning. Hopefully that is the fix.
06-26-2016, 08:20 AM #8Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
it is a slim very slim chance that you will pick up trash from your fuel that water separator will pick up all solid stuff new pump these day less then 70.00 im thinking your stator low side winding is toast
Mercury Tech: 1994 200hp Mercury 2.5 EFI XRi Switchbox
By FL_Sanger_Barefooter in forum Technical DiscussionReplies: 6Last Post: 06-17-2016, 03:33 PM -
1994 200hp mercury efi
By Mak in forum Technical DiscussionReplies: 4Last Post: 05-06-2016, 07:46 PM -
1994 XRI 2.5L 200HP MAX RPMs (details inside)
By Burchoid in forum Technical DiscussionReplies: 6Last Post: 09-25-2013, 12:52 PM -
1994 Mercury XRI 200hp Engine mods?
By blowitup in forum Technical DiscussionReplies: 2Last Post: 08-25-2011, 11:06 AM -
1994 2.5 200hp mercury cowls
By chaudron in forum General Boating DiscussionReplies: 3Last Post: 08-20-2008, 07:04 AM
