Results 16 to 18 of 18
06-29-2016, 12:39 PM #165000 RPM
- May 2011
- Ft. Lauderdale
- 625
My transducer is mounted down inside my bilge area and reads bottom whilst running, no problem.
06-30-2016, 09:59 AM #17
A lot of guys mount a small piece if King Starboard or PVC board to the transom then mount the ducer to that so you can move it without redrilling but your ducer should have a good amount of up/down adjustment without redrilling. I would set it as I described above and put your screws at the bottom of the slots so you can go down a little if needed.
If you mount it in the bilge I think you wil be very happy. I do mine a little different. I take some plumbers putty and make a little "pool" that the ducer will sit in. Fill that about half way with a slow cure liquid epoxy. You want to mix your epoxy slow not creating any bubbles. Set the ducer in the pool by kind of rolling it from one edge. This will eliminate trapping any bubbles and the slow cure will allow the bubbles to dissipate before it cures.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
06-30-2016, 10:01 AM #18
Also some epoxies contain metal or other fillers. Thats why I like a clear liquid epoxy.
21' Paramount
Mercury 300 Promax
Post your Paramount Pics!!
By BUD in forum General Boating DiscussionReplies: 452Last Post: 12-10-2018, 11:38 AM -
In hull transducer mounting Paramount
By maineidyl in forum Technical DiscussionReplies: 4Last Post: 11-04-2009, 02:19 PM -
Pour in Transoms???????
By Georgia Boy in forum General Boating DiscussionReplies: 26Last Post: 07-28-2003, 10:46 PM -
Rotted transoms a humidity problem?
By cobra147 in forum General Boating DiscussionReplies: 4Last Post: 05-14-2002, 11:03 PM
