Results 16 to 26 of 26
06-26-2016, 05:49 PM #16Junior Member
- Jun 2016
- Miami, Fl
- 9
When you say plug all of the oilers do you mean all six of the small lines going to my cylinders or everything including the ones to the manifold and all intertwined through the carbs.
06-26-2016, 06:53 PM #17
The small lines intertwined though your carbs are the primer lines.. you're gonna need them. And the ones coming off the cylinders are re-circ lines as far as I know. Both my V6 loopers have them.
Speedcraftdave liked this post
06-27-2016, 07:23 AM #18Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
I would get a service manual for an 88 up carb engine as it will show hose routing and what is needed.
06-27-2016, 08:28 PM #19Junior Member
- Jun 2016
- Miami, Fl
- 9
Just ordered one, thanks
07-02-2016, 10:54 AM #205000 RPM
- Nov 2001
- ft. wayne,In
- 692
- 16
- 7
- 52
- 9
that intake looks familiar. How is it working out for you? Any noticeable gains?
07-03-2016, 03:21 PM #21Member
- Oct 2012
- Moline, Illinois
- 84
- 12
Well, it for sure hasn't hurt anything. Knocked the engine apart and did a lot of work over the spring so anything from just the intake is unknown. Been making good power up through 7500 on just 120 psi cranking so it's definitely not hurting.
07-06-2016, 11:13 AM #22Junior Member
- Jun 2016
- Miami, Fl
- 9
Can anyone tell me if I'm missing anything from my ignition list?
1. Upper bearing carrier
2.stator
3.timer base?
4.powerpack
5.flywheel
07-06-2016, 11:57 AM #23Member
- Oct 2012
- Moline, Illinois
- 84
- 12
Linkage?
07-06-2016, 03:59 PM #24Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Voltage regulator, mounting hrwd, wire harness, trim relay box
Speedcraftdave thanked for this post
07-06-2016, 04:02 PM #25Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Intake styles. Three main ones, first on the 86 to 89, 90 to 95 then the 96 on which is basically the same on the carb engine and ficht engines.
10-08-2016, 03:49 AM #26Member
- Jan 2004
- Florence, AL
- 30
I have everything needed to do the swap x10. If you want to run oil injection I would recomomend new VROs and I would also recommend new power packs.
Help With '98 Looper Carbs/Throttle Body "Idle Adjustment Screws"!!!
By rockman69 in forum Technical DiscussionReplies: 4Last Post: 07-07-2015, 01:13 PM -
1983 21 Sanger "classic" OB with Merc 225 engine and stringer transom rebuild/Resto.
By Zoomba in forum Technical DiscussionReplies: 2Last Post: 09-02-2013, 10:41 PM -
2001 225 ficht "no oil"
By Habbi in forum Technical DiscussionReplies: 6Last Post: 09-18-2005, 06:34 AM -
"cold start" feature & rough idleing OMC Looper
By imq707s in forum Technical DiscussionReplies: 2Last Post: 05-29-2004, 05:25 AM
