Results 1 to 15 of 17
    Sep 2012
    Miami
    Mercury 200 Powerhead Assembly
    Mercury 200 Carbureted - 2 Cylinders had low compression - Engine sent to Layton Marine in Miami - 1 Cylinder sleeved - 1 Cylinder bored 0.10 over - Heads milled 0.10 - Crank checked and polished - Pistons checked - Block, Crank, Pistons, Heads, etc.. All Parts Dispayed are good
    Contact: Mike 786-217-5410
ID:	346526   Click image for larger version.
ID:	346527   Click image for larger version.
ID:	346528   Click image for larger version.
ID:	346535   Click image for larger version.
    R.I.
    Whats Are you looking to get for it?
    Sep 2012
    Miami
    Quote Originally Posted by CKMATE225 View Post
    Hello CKMATE225, I'm asking $550.
    R.I.
    I may be interested where are you located? will you ship it if needed?
    I need a little more info to see if its what I need, is it a 2.5? and do you know the approxamate year?
    Sep 2012
    Miami
    No problem. The engine is in Miami, FL near 33185 and is a 2.4L.
    I think it's an 88', based on the boat it came off of. The S/N I pulled from the midsection is
    S/N: 06461609
    Aug 2014
    washington
    What parts does it need to run? Looks like a flywheel and electronics?
    new york babylon
    Not to hijack but I have ingintion carbs and flywheels for it posted in misc parts
    Dec 2006
    Central N.J.
    It's late 70s or early 80s.
    Head bolts are in the sleeve.
    Grady White 226 Seafarer 225hp
    Maxum 1700XR 90hp
    Ranger 365V 150hp
  9. Thanks DirtySouthMikey thanked for this post
  10. #9
    Sep 2012
    Miami
    Hey all, thanks for the info. I have the rest of the engine, flywheel, hardware, etc.. It's all included.
  11. #10
    Apr 2016
    Victoria bc canada
    Quote Originally Posted by DirtySouthMikey View Post
    Would you ship to Canada?
  12. #11
    1983 2.4 200 elpto
  13. Thanks DirtySouthMikey thanked for this post
  14. #12
    Dec 2011
    Ludington michigan,on the shore
    That power head is a first generation,last built about 81.Are you sure it's a 200,what is the bore size.A 200 would be a chrome bore,and would not be able to be bored.010 over,unless it had been sleeved before in that hole.Also I beleve the front cover is from a later motor,the first gen 2.4 were vertical reed except the 225 and it would be seven petal.
  15. Thanks DirtySouthMikey thanked for this post
  16. #13
    Serial number from mid says its a 1983 2.4 200 as we know things change, at least thats what the clamp is
  17. Thanks DirtySouthMikey thanked for this post
  18. #14
    Sep 2012
    Miami
    Hello, sorry for the late reply. I would ship to Canada if you prepay the shipping and merchandise.
  19. #15
    Sep 2012
    Miami
    Hello Outasite, very impressive. Yes, this powerhead has been worked on prior to me taking it to get Reworked. Fortunately, the guys from Layton Marine are the same people who have worked on it both times. Cylinders #2 and #3 have been sleeved, the other 4 cylinders are Chromed.
  1. Replies: 6
    Last Post: 05-18-2016, 09:45 PM
  2. 3.0L Mercury Gearcase Assembly
    By Thunderduck in forum Technical Discussion
    Last Post: 02-11-2011, 08:25 AM
  3. Mercury trigger assembly
    By ranger350v in forum Technical Discussion
    Last Post: 03-22-2006, 10:05 PM
Diamond Marine
