Results 76 to 90 of 117
Thread: Balsa core lamination
08-12-2016, 10:49 AM #76
I used rustoleum topside with grit for the floor.
W2F a V-King thanked for this post
09-21-2016, 08:18 AM #77
Nice to see another Hydrostream in the neighborhood. Im only about 20 minutes from the Cambridge area. Just north of Saint Francis a little bit. Next spring/summer maybe we could hit up a few lakes. I have been itching to get my Vulture on the water and I am just about there.
-Kevin
1982 Hydrostream Vector
1982 Hydrostream Vamp
1973 Hydrostream Vixen
04-11-2017, 10:31 AM #78
What type and weight of fiberglass should I put over a core?
04-11-2017, 12:30 PM #79Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
04-11-2017, 12:43 PM #80Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
On a 1/2'' balsa, a 1708 bi-axial would be good. Cover it with some 3/4 oz matt to make it water proof. This is with poly or vinyl resin. With epoxy you could use some 1700 bi-axial and just resin coat it to seal it from getting wet. I am seeing a Stream in your pic, so that is what you are coring?
04-11-2017, 01:17 PM #81
Yes guys I have a HS Virage I am going to put a core, stringer(knees) and transom in very soon. Already have the boat in the garage on blocks and all the old wood ripped out.
I am going to use 1/2" thick balsa and epoxy resin. Using cabosil to thicken it as I put the core down. I have worked with epoxy plenty of times before as coatings, just not as much glass work.
04-11-2017, 01:29 PM #82Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
1700 is the weight I would use then.....If you want to go a little heavier, use some 24oz bi-axial. Main thing is to seal it up good. Roll some resin on the balsa and let it set up. Then run your glass over that and let it set up. Then flow coat the surface....Stringers could be on top of the core for more even load dist. Less stress points on the hull skin.
04-11-2017, 02:10 PM #83
So that is 17 oz 45 fabric? I was thinking of doing it like dwilfong he used 1700 all over the boat like the core and the floor
I am thinking 3 sheets of 1/2" marine plywood for the transom with a 1.5oz mat inbetween each layer..what do you think??
04-11-2017, 02:19 PM #84Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Yes, on the 0/45 fabric. For everything. And I would skip the matt in the transom and use the same putty mix as you used for the core between the sheets and to bond it to the hull. If you were using poly then yes, use some matt. But epoxy is so damn strong and super adhesive it is a better glue than the stuff holding the plywood together. Save weight wherever you can.
04-11-2017, 02:29 PM #85
0/45 ?? what kind of glass is that ???? never heard of that one before! would be pretty useless !!
IF YOU USING EPOXY resin YOU DONT WANT TO BE USING CARBOSIL TO THICKEN WITH !! has no guts what so ever ! actually makes the resin brittle ! check out the west system recommendation ! they are a really big help !Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
04-11-2017, 02:41 PM #86
Then what do you mix it with? the 403 stuff is too expensive
04-11-2017, 03:23 PM #87
And another question, how many layers of the 1700 over the core floor and transom?
04-11-2017, 03:33 PM #88Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
I used 1 layer of the 1708 oz bi-ply over the foam core in my V-King. For the transom, I would add some to the hull skin to get about 1/4'' thickness, install transom and then cover with 2 layers. 2 more over that where the motor bolts go thru is helpful. Stringers and knees, 2 layers is plenty. Floor depends on what is being used for core. Usually 1 layer under, and 1 layer over with an additional 6'' tab pc on the floor edges all the way around is good. So 2 layers at floor seam...
04-11-2017, 04:07 PM #89
Gotcha ok, I think my transom skin is like 1/8-3/16" so I will build that up with some 1708 fiberglass to 1/4" thick then put in my 3 layers of 1/2" thick marine plywood transom
I need to find a way to keep the transom straight, it has a slight curve in it. Not bad at all but noticeable with a straight edge
04-11-2017, 04:29 PM #90Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Go to a scrap yard or metal fabricator and find a couple of pcs of straight steel ell angle (L) and screw from the outside into the wood possibly using the motor mounting holes. One pc at the top and one lower. Need the trans flat for sure....
Balsa Core
By huck_this in forum Fiberglass and Composites DiscussionReplies: 8Last Post: 05-05-2009, 07:37 PM -
balsa core, what would you do?
By rjdubiel in forum Fiberglass and Composites DiscussionReplies: 42Last Post: 05-14-2008, 10:37 AM -
Balsa core
By fijjity in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 07-10-2006, 05:14 PM -
where to buy balsa core?
By Tony P in forum General Boating DiscussionReplies: 3Last Post: 09-08-2005, 12:46 PM
