Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
    Jun 2016
    wildomar, ca
    Again, read the add.... I have not had my hands in this engine it was on the boat when purchased. I pulled the heads because I could tell the engine had been apart and wanted to a least get some info on the top end and saw that there were"5" newer pistons. "4" std. and"1" being .030 over. That would leave "1" piston being the hurt one a stock piston. For not pissing on my add, I think you have done a great job of it.!!!
  2. #17
    Jul 2002
    FT WORTH, TEXAS
    your statement "The powered did not grenade, and was was running fine when last ran. The shops from California to Texas I called (proven 2.5 builders) had told me it was worth 3500- 3750 the way it sits so that's what I'm going off. Engine needs a sleeve and piston. That's it!" is what touched it off for me i should have just left it alone even though i know better glws
  3. #18
    FL / NY
    Just a bit of helpful info to maybe consider.
    I have been told that $5000 for a freshly rebuilt, with all key parts new plus a new OEM block is a bit high, go figure.....
  4. #19
    May 2008
    North East,M.D.
    There are two dealers that sell new rebuilt 200 promax,s carb. here in de for $7500 with a three year warranty. Complete outboard. bolt and go.
  5. #20
    Jun 2016
    wildomar, ca
    Willing to start separating the pieces and posting in the appropriate section. Thanks, Jhered.
  6. #21
    FL / NY
    Quote Originally Posted by Fast-Trukin View Post
    Even though that sounds like a good price for a complete motor a 200PM is an EFI motor and a 200PM is NO 225PM.....JMPO
  7. #22
    Jun 2016
    wildomar, ca
    cowl, powerhead, mid, 1.87 c.l.e. complete setup for $3500 obo
  8. #23
    Mar 2011
    SOUTH,MISSISSIPPI
    I would buy the Bare Block ! Back & Front only Pm me a price if interested !
  9. #24
    Mar 2014
    south carolina
    Would you sell the steering seperate?
  10. #25
    Jun 2016
    wildomar, ca
    Quote Originally Posted by railey View Post
    Yes, $600 for the rack, helm and lines.
  11. #26
    Mar 2014
    south carolina
    Quote Originally Posted by lowerriver View Post
    Is that everything I would need or would I have to buy something else?
  12. #27
    Jun 2016
    wildomar, ca
    You would need oil and I will double check to see if the hose fittings on the rack end are reusable. The rack mount and hardware will be included. No steering wheel.
  13. #28
    Duluth, MN
    Do you still have the power head and mid interested if you want to part it out
  14. #29
    Duluth, MN
    PM sent
  1. Mercury Tech: How bad did I hurt this 3.0l
    By activator22 in forum Technical Discussion
    Last Post: 10-22-2012, 07:27 PM
  2. Mercury Tech: will it hurt
    By cobiawayne in forum Technical Discussion
    Last Post: 09-25-2009, 08:58 PM
  3. This had to hurt......
    By VectorPat in forum The Scream And Fly Lounge
    Last Post: 12-24-2005, 02:43 PM
  4. Okay, this is going to hurt!
    By Scream And Fly in forum The Scream And Fly Lounge
    Last Post: 03-09-2003, 04:44 PM
Diamond Marine
