Results 1 to 10 of 10
    Jun 2009
    Louisville
    Which prop to use for a 1985 Hydrostream Valero
    I need help figuring out which prop to use for my 1985 Hydrostream Valero v bottom boat. I have a Mercury 150 pro max rigged to it. I have just been using a standard 25P quicksilver prop and I'm getting around 62 mph and 6500 rpm's. The boat chyna walks around top speed so I don't need anymore bow lift. I think I need some sort of chopper prop but not sure which pitch to start with or what style of chopper prop I need. Any suggestions would help!
    Jun 2009
    Louisville
    Pictures of Hydrostream
ID:	345178   Click image for larger version.
ID:	345179   Click image for larger version.
    China Wok????
    Sum ting wong!!!!!!
    Post a photo of the gearcase. Do you mean the boat tops out at 62, or you can't drive past it?
  4. Likes Robby321 liked this post
    Mississauga Ontario
    omc srx, mercury ET lightining, mazco re are all good for that hull.
    1991 Hydrostream AE-21 1997 Evinrude Vindicator 225
    Windsor, Ontario
    You have to learn to control the chine walk. Do you have solid mounts and a foot throttle?
    Jun 2009
    Louisville
    Quote Originally Posted by David View Post
    I have a jack plate and it's set up even with the bottom of the hull. I was wrong in the description though. I am currently getting 5200 rpm's. I kno that I need to turn more rpm's than that. Yes I do have a hot foot.
    Jun 2009
    Louisville
    Thanks. I haven't heard of them but I will try and look them up. What pitch would you suggest if I'm only getting 5200 rpm's on a 25 pitch standard prop.
  9. #8
    Mississauga Ontario
    post a pic showing the side of your lower unit in relation to the bottom of your hull , when you say "even" your prop shaft centre line should be even with the bottom of the hull pad when trimmed so its parallel. Post a pic and more help will come.
  10. #9
    Quote Originally Posted by Josh Reed View Post
    Thanks. would you suggest if I'm only getting 5200 rpm's on a 25 pitch standard prop.
    I would suggest repairing the motor first, it should be turning 7 grand with that thing.
  11. #10
    Jun 2009
    Louisville
    Quote Originally Posted by panther150 View Post
    Okay I will. I have it stored in a boat shed near the lake so I will take pictures this next weekend.
    Thanks
  1. Replies: 2
    Last Post: 07-10-2015, 09:11 PM
  2. Hydrostream Valero, Which Prop? need more bow lift less stern lift,
    By Dregsz in forum Props, Setup, and Rigging
    Last Post: 09-10-2014, 08:21 PM
  3. Hydrostream Valero, V6 150, ideal prop and RPM?
    Last Post: 03-17-2014, 11:55 AM
  4. 1985 Bridgeport EFI on 1985 STV Shovelnose prop question
    By MISSING in forum Props, Setup, and Rigging
    Last Post: 02-28-2012, 03:53 PM
Diamond Marine
