Results 1 to 5 of 5
Thread: Cooling down a 280 mods
05-27-2016, 11:58 PM #1Member
- Mar 2013
- mobile Al
- 92
- 14
I've seen the dry-stack mod. I plan on doing it soon.
However, for the mean time is there anything a little more simple or quicker I can do in the meantime to get it a few degrees cooler? It's currently running 160-165° on longish runs
Thanks.Last edited by dondante; 05-29-2016 at 03:24 PM.
05-29-2016, 12:52 PM #2
Warmer. Why?
drystack is a total waste of time and money.2023 TUFF 25
05-29-2016, 01:54 PM #3Member
- Mar 2013
- mobile Al
- 92
- 14
Warmer? I want it cooler.
05-29-2016, 02:22 PM #4
I see some 300 drags have a water bypass hose from the top of the block, going to the heads between 3-5 and 4-6 I assume that water is a little cooler,and would pull heat away from that area.Someone do tell!! JFYI your post stated you wanted it warmer!
05-29-2016, 03:24 PM #5Member
- Mar 2013
- mobile Al
- 92
- 14
OMC Tech: 70hp 3 cyl cooling mods?
By roycesrolls in forum Technical DiscussionReplies: 10Last Post: 07-25-2012, 01:09 PM -
Search on cooling mods
By codyc in forum Technical DiscussionReplies: 3Last Post: 12-20-2010, 01:50 PM -
Mercury Tech: Cooling mods cont.
By dwiggl in forum Technical DiscussionReplies: 5Last Post: 04-16-2010, 11:05 PM -
Cooling mods and thermostats
By Burke Kilgour in forum Technical DiscussionReplies: 79Last Post: 01-20-2004, 11:00 AM -
Block cooling mods ????
By Superdave in forum Technical DiscussionReplies: 3Last Post: 01-19-2003, 04:47 AM
