Results 1 to 15 of 25
Thread: Thru Hull Plumbing Question.
05-27-2016, 08:06 PM #1
When using thru hull plumbing on a sportmaster lower to feed water should the original three water pickups be plugged or is there enough volume that it should not matter. I am really considering this and just want to make sure I don't screw anything up.
Many thanks, Carter
05-28-2016, 08:41 AM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
leave em be.
05-28-2016, 09:07 AM #3
05-28-2016, 11:11 AM #4
OK I am confused! If they are left open what would or could happen. If closed completely what should I expect. Open or closed?
Thanks, Carter
05-28-2016, 11:21 AM #5
If case is really high you cab dump water out if cone if not welded shut and no check valve on transom pickup
05-28-2016, 12:19 PM #6
Ok, so I can see the need for the check valve to keep water from draining back into the lake. Here is what I am not sure of. If the lower unit pick up holes are welded shut and you have a check valve it would seem that you are running the water pump impeller in a dry mode. If the pickup holes are open you are drawing water directly to the water pump. Would leaving the lower unit pick up holes open drastically lower water pressure if the pick up holes were were out of the flow of water?
Thanks, Carter
05-28-2016, 12:34 PM #7
You don't need to close them, even if you have them above water line, the water being introduced into the adapter plate will leak enough down to lube the impeller. Where the check valve needs to be is at the thru hull, at idle the water the pump is pushing will go out of the adapter and out of the thru hull until you have enough forward momentum to over come it. Another reason to leave the holes open, easiest way to run on the hose.
is gone
05-28-2016, 02:33 PM #8
Thanks for the last reply, that is what I was hoping to hear. Could you recommend a certain type or brand of check valve.
Best wishes, Carter Powell
05-28-2016, 02:38 PM #9
just make sure it's a brass, swinging gate
What boat are you putting it on?
is gone
Frank Molé, tux974 liked this post
05-28-2016, 03:12 PM #10
OK, just one more question,I promise. If you were going to do what I am wanting to do, what size and type of hose would you use. Also what type of connectors would be the most reliable.
Again, Thanks, Carter
05-28-2016, 04:20 PM #11
AN #12 and 3/4 npt ,but I'm cooling 2.5's, some folks on the other thread say this is to small for big blocks, I have no experience on them. As far as type of hose, if your chicken about possible blown hose, sunk boat , go with a mild Parker crimped end hydraulic hose, at least for inside the boat, mine are 700psi which is low for hyd. hose but more flexible.
What motor/boat combo are you using?
is gone
05-28-2016, 05:11 PM #12TRANSPORT SERVICE...UP TO 36 FEET....YOUR TRAILER OR MINE... FULLY INSURED...............
DOT & CDL COMPLIANT $500,000.00 CARGO & 1 MILLION LIABILITY.
LIVE LIFE ON THE EDGE, LESS CROWED BETTER VIEW
05-28-2016, 05:40 PM #13
Frank, your running a big block, what size fittings/hoses do you have?
is gone
05-29-2016, 05:19 AM #14
Frank Molé thanked for this postFrank Molé liked this post
05-30-2016, 11:46 AM #15
225X plumbing question
By LongShot in forum Technical DiscussionReplies: 13Last Post: 10-11-2014, 03:45 PM -
Thru hull water pickup parts and plumbing information
By Carter Powell in forum Technical DiscussionReplies: 7Last Post: 03-01-2012, 03:08 PM -
Mercury Tech: Water pressure & poppit plumbing question 2.4 200
By ssv1761982 in forum Technical DiscussionReplies: 17Last Post: 09-02-2008, 08:45 PM -
Fuel plumbing question
By Revin in forum Technical DiscussionReplies: 7Last Post: 06-19-2008, 02:36 PM -
mercury plumbing Question
By Nitro 929 in forum Technical DiscussionReplies: 1Last Post: 05-24-2007, 09:43 PM
