Results 1 to 15 of 43
05-25-2016, 09:43 AM #1
Alarm going off when throttling up on Mercury
Purchased boat with Mercury 225 pro max 1995,Just put on hose and idles fine but when throttling up beeping starts.Any ideas where to start diagnosing?
05-25-2016, 11:58 AM #2
is the oil injection still intact?if so,id pull the pump and drive shaft and have a look at the drive gear on the crankshaft.they are notorious for stripping teeth.
05-25-2016, 01:11 PM #3
Describe the alarm... comtinous or pulsing beep
Go Time
26 Regulator twin 250 EFI
05-25-2016, 02:21 PM #4The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
Mid 90's first generation 3 litre gearcases also had a side water intake issue, in that the shape of the gearcase had a hump on the sides, just ahead of the water intakes themselves, causing air to be introduced to the intakes. This happened to be where the pinion gear was inside & they thought they needed the humps there. Mercury redesigned/improved the gearcase shape & intake design the following years, and the problem mostly went away. This may or may not, be part of your situation.
SUNKIST liked this post
05-25-2016, 03:02 PM #5
Go time,its a pulsing beep/beep.This is the history:I was under the dash cleaning up wiring and found tan/blue wire broken or cut going to alarm buzzer and the purple was connected.So i reconnected tan/blue.I finally got around to getting the boat ready for season and now beeping sound off idle is present.The boat has twins so i can try robbing parts from other engine.
05-25-2016, 03:10 PM #6
Skeeter yes oil injection still present,Do not want to remove because boat has twins and separate tanks.
05-25-2016, 03:32 PM #7Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Dunno if yours has it, but there is a neutral safety switch on the 3.0's that will make the comp think the motor is in neutral and will beep and limit the r's to 1500-1800 when you give it throttle. It's on the shift slide. Disconnect and jump the 2 motor side wires together to test. Just a guess....
05-25-2016, 03:37 PM #8
X have no switches,I can Rev to 6k
05-25-2016, 04:04 PM #9Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Darn, oh well. Back to the oil system
05-25-2016, 04:09 PM #10
Going to take oil shaft out tomorrow.I'm burned out chasing the "beep"
05-25-2016, 04:43 PM #11
05-25-2016, 06:54 PM #12The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...In a twin engine installation, this gearcase design shape problem was amplified, due to the crabbing nature of the gearcase as it goes through the water, because twins have a tie-bar that is always adjusted to "Toe In". (Which is incorrect by the way, but everyone does it.)
05-25-2016, 08:38 PM #13
Swapped warning modules with no success.Leaning towards stripped oil injection gear it has hall effect magnet pickup on top of gear housing.
Transom,can post wiring diagram?It beeps even stone cold with water on while raising rpms .
05-25-2016, 09:44 PM #14
Temp will be a steady beep. Beep Beep = oil injection.
05-25-2016, 11:29 PM #15
i had a steady beep i traced it to the new livorsi temp gage un hook power to gage tone was slient what i had to do was run a jumper from neg to neg on batterys all quiet must be a ground thing on one of the batterys .
Mercury Tech: Mercury 200 Alarm
By hangn in forum Technical DiscussionReplies: 3Last Post: 02-06-2016, 02:02 AM -
Mercury Tech: 1993 Mercury 50 Alarm
By hevysrf in forum Technical DiscussionReplies: 1Last Post: 06-09-2011, 09:25 AM -
Mercury alarm
By hydrostreamin! in forum Technical DiscussionReplies: 1Last Post: 05-19-2010, 12:06 PM -
Intermittent alarm on Mercury engine
By MikesXpress in forum Technical DiscussionReplies: 1Last Post: 06-23-2008, 10:06 PM -
Mercury 225x Alarm ??
By REBEL in forum Technical DiscussionReplies: 3Last Post: 09-07-2003, 10:59 PM
