Results 31 to 43 of 43
05-28-2016, 07:14 PM #31
05-28-2016, 07:22 PM #32
There's a reason somebody cut that wire
05-28-2016, 07:29 PM #33
Yea that's why going nuts trying to diagnose this quagmire
05-28-2016, 07:44 PM #34
After some looking, I don't think that wire is even used, except for a visual warning system.
05-28-2016, 08:00 PM #35
Tan Blue should be for the warning horn. Maybe he has a temp sender for a gauge hooked to the warning horn wire. ????
05-28-2016, 08:21 PM #36
05-28-2016, 08:27 PM #37
MERC WIRING.pdf
Check out the Promax wiringLiving in the Freedom provided by Bud Conner and his fellow warriors.
05-28-2016, 08:43 PM #38
Yup the tan/blue coming from the switch #1 is what sets the overheat alarm. Not sure why it goes to the module unless they back the timing off when it switches. The temp sensor is what feeds the gauge and tells the ECU what temp the motor is. Why he is getting a beep Beep and not a steady beep leads me to believe it's an oil issue .
05-28-2016, 09:36 PM #39
I traced tan with blue tracer from alarm horn under dash goes to junction above switch boxes then goes to oil alarm.Now I swapped ever part over check gear.My next thought is other switch box because I have wire going from module to switch box.Do you guys think switch box could cause voltage decrease over 2000 rpms?
05-28-2016, 11:37 PM #40
Only one way to find out. Give you credit your the only man I know that has tried this hard to figure it out. Most would just toss all the injection stuff and pre mix and move on.
tux974 liked this post
05-29-2016, 07:26 AM #41
The alarm circuit is simply a sounder going to 12V. When it is grounded the circuit completes and the alarm sounds.
At the terminal strip over the switchboxes, one wire goes to an overtemp switch in the head, and the other goes to the oil alert system. If either one is grounded, the alarm sounds.
To test, disconnect the wire to the temp switch and try it. If the alarm sounds, the trouble is in the oil alert system, (with all it's appendages previously discussed.) If the alarm doesn't go off at 2000 rpm, then something is funky about the temp sender.To fish or not to fish? What a STUPID question.
06-01-2016, 12:29 AM #42
Oil injection removed,just waiting on plugs.Is it normal to have no beep when key is turned to run.Will there be a buzzer on overheat condition or is that deleted when oil module is removed?
06-01-2016, 06:08 AM #43
Yes and Yes.
Mercury Tech: Mercury 200 Alarm
By hangn in forum Technical DiscussionReplies: 3Last Post: 02-06-2016, 02:02 AM -
Mercury Tech: 1993 Mercury 50 Alarm
By hevysrf in forum Technical DiscussionReplies: 1Last Post: 06-09-2011, 09:25 AM -
Mercury alarm
By hydrostreamin! in forum Technical DiscussionReplies: 1Last Post: 05-19-2010, 12:06 PM -
Intermittent alarm on Mercury engine
By MikesXpress in forum Technical DiscussionReplies: 1Last Post: 06-23-2008, 10:06 PM -
Mercury 225x Alarm ??
By REBEL in forum Technical DiscussionReplies: 3Last Post: 09-07-2003, 10:59 PM
