Results 1 to 15 of 15
Thread: Carbed motors in rough water??
05-23-2016, 09:29 PM #15000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Ive got a 2.4 carbed bp motor that cuts out in rough water for a split sec on impact of 2' waves or bigger... just wanting to know if it was possibly the carb floats doing something to make it drop rpm then pick up again. .
05-24-2016, 01:08 AM #25000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
some hp motors had a slosh plate in carbs,others will chime in shortly-th
05-24-2016, 06:12 AM #3
Ok im searching my memory but I remember someones boat in our shop that did this and it turned out to be the trim limit module. Just a thought. You may or may not have one.
Slimm liked this post
05-24-2016, 11:49 AM #4
we raced carb motors for many yrs,,,,,
3 things I found to keep em crisp in the rough
if floats are set to high fuel will splash up through the brass vent tubes into the ventura
and momentary flood the motor
so have to set them a bit lower/below level
baffles mounted in the float bowls help a lot to keep fuel from sloshing upward towards the vents
and flip the primer solenoid upside down,,,,,with the primer mounted upwards and have wave impact sometimes primer can open and add fuel
05-24-2016, 12:43 PM #55000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
ok thanks guys ill look into all of that.....
05-24-2016, 12:45 PM #65000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
I do have a trim limit thing on engine harness.... can I do away with it some how to elitmate that possibity.
05-24-2016, 02:59 PM #7
Yes you can.
RockTeam Junk
05-24-2016, 03:19 PM #8
yes its like a mercury switch, liquid metal mercury, it would "splash" around and intermittently cut motor out
05-24-2016, 05:58 PM #95000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Ok i took the trim limit piece off and taped the wire up and out of the way... ill try it like that first. .
05-24-2016, 07:42 PM #10
I had a battery switch die on me every now and then.
06-02-2016, 10:17 AM #115000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Trim limit switch was the problem thanks so much guys..
1BadAction thanked for this post1BadAction liked this post
06-02-2016, 10:25 AM #12> Stainless steel Merc cowling plates - $110 shipped TYD - LINK <
06-02-2016, 10:26 AM #135000 RPM
- Oct 2015
- Kentucky lake
- 480
- 31
- 15
- 60
Yea I've got my confidence back in boat again
06-02-2016, 10:49 AM #14
I have seen that switch cause issues more than once. Glad ya got it going.
RockTeam Junk
06-02-2016, 05:06 PM #15
25' to 30' rough water V bottom running Twin outboard motors who's got the fastest?
By Omni Present in forum General Boating DiscussionReplies: 634Last Post: 08-19-2015, 01:57 PM -
Nissan 40 hp carbed water pressure ?
By NNT in forum Technical DiscussionReplies: 0Last Post: 06-19-2007, 03:02 PM -
Rough water
By Pro300x24LD in forum General Boating DiscussionReplies: 8Last Post: 09-12-2006, 09:59 PM -
SoCal Poll - Rough Water - Smooth Water
By company man in forum General Boating DiscussionReplies: 3Last Post: 05-26-2005, 12:21 AM -
Two Carbed Motors Off One Electric Fuel Pump??
By Instigator in forum Technical DiscussionReplies: 8Last Post: 03-15-2004, 04:39 PM
