Results 1 to 15 of 25
05-23-2016, 09:07 PM #1Junior Member
- Jan 2015
- Lodi WI
- 21
- 9
Engine cover cracks on the rear of a 2013 mercury 300xs?
I am fairly new to Scream and Fly, I just recently bought a 2015 Liberator, I am the second owner. The motor is a 2013, put into service in May of 2015. It has 34 hours on it. I found a crack on the right rear of the engine cover, there is also stress cracks on the left side of the cover (which I am sure will be a crack shortly). I took it to my local Mercury dealer to get it warrented, its under manufacturer warranty until May of 2017. They took pictures, told me it looked like a defect to them, and sent the pictures to Mercury. This boat and motor are immaculate, absolutely no signs of being hit or dropped etc. I just received a call from the dealer and they told me Mercury will NOT cover it!!!!! They would not say why, or what they think may have caused it, just no... I have not called Mercury myself -yet, but I will asap. Has anyone else dealt with this situation, I am sure mine is not the only one with this problem. Anyone from Mercury reading this? I would love to talk with you.... Thanks, Steve.
Like I said, Im new to scream and fly, not sure this is the right area to post this? Any help would be appreciated...
05-23-2016, 09:45 PM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7151
- 3 Post(s)
They are water suckers anyway. This is just a good reason for you to get an updated one from RGR. I am not trying to make light of it but you really do want something different that doesn't create the low pressure area behind the cowl at speed and coats your motor the way the stock XS cowls do at 90 and up.
shadow1986 liked this post
05-23-2016, 10:05 PM #3Junior Member
- Jan 2015
- Lodi WI
- 21
- 9
Where can I find/buy one? I just tried looking it up and didn't find anything. Thanks.
05-23-2016, 10:58 PM #45000 RPM
- Sep 2012
- Florida
- 441
- 15
- 9
- 84
I have 2 and both of the covers are cracked in the rear corner.
05-24-2016, 08:34 AM #5Junior Member
- Jan 2015
- Lodi WI
- 21
- 9
Were they still under warranty? What did Mercury say to you? I'm
05-24-2016, 09:17 AM #6Junior Member
- May 2014
- Ontario
I have a 2015 that cracked at the bottom right side back of motor. Mercury denied warranty coverage. Ordered new engine cover (not cheap) and it doesn't fit. They are way to tight. I suspect mine cracked during the winter during cold temps. Dealer now back to Mercury to discuss my issue.
05-24-2016, 10:09 AM #7Junior Member
- Jan 2015
- Lodi WI
- 21
- 9
They obviously have a design problem here, and it doesn't take an engineer to see this. Please keep me informed with what happens with this go around with Mercury. I have never had to take anyone to court before, but it's starting to look like that may be my only option?
05-24-2016, 10:14 AM #8Junior Member
- May 2014
- Ontario
I'm from Ontario, Canada and purchased boat and motor from Dave at Liberator boats in Texas. Sent him a mail and he is going to check with Mercury. Local dealer is working on the claim again since the new cover does not fit. He said maybe they would have to change the mid section. But based on others having the same problem that will not be a valid solution. I will post up once i hear back. By the way it took Mercury 2 weeks to sit on and then deny the claim. Not impressed
05-24-2016, 04:22 PM #95000 RPM
- Sep 2012
- Florida
- 441
- 15
- 9
- 84
05-24-2016, 05:04 PM #10
Friend had one a new under 10 hr 300xs last year and Merc warranted it.
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
05-24-2016, 05:28 PM #11Junior Member
- May 2014
- Ontario
Merc told my dealer it is a customer problem and that they often push down to hard on cover. That's really funny since I have never had the cover off myself and it has only been off twice both times by a Mercury mechanic. And replacement cover doesn't fit. Your friend was fortunate and I suspect because the motor was so new. Mine was 10 months old when I discovered the crack after pulling out of winter storage
05-24-2016, 06:19 PM #12
Depends on the engine warranty; the XS stuff has a "limited" warranty now so Mercury makes the call on any kind of claim. I have a set in boxes that one of the plastic fittings is broke, but the cowl/pans are not damaged.
http://www.screamandfly.com/showthre...0-XS-Cowl-Pans(608) 884-9415
www.rockrivermarina.com
05-24-2016, 08:43 PM #13
I noticed mine were tight from the factory and that the seal design was thicker on outside than the inside, so pulled the seal and reversed the direction. They weren't as tight that way.
I now have Mike Nass alien style cowls with ram air duct and love them.Last edited by jpf091959; 05-24-2016 at 08:46 PM.
05-24-2016, 09:48 PM #14Supporting Member
- Apr 2003
- 6,645
- 606
- 923
- 1699
- 7151
- 3 Post(s)
05-24-2016, 10:40 PM #15Junior Member
- Jan 2015
- Lodi WI
- 21
- 9
I used to work for a local Ford garage as a technician, and I am just wondering how the customers that just bought a 40-50k boat/car/truck would react to finding they have a broken/cracked hood while still under warranty - when they took it in to get fixed they were told that they pushed down on it to hard, or opened it when it was cold out!!! WTF??? In one day I have found out that there is definitely a problem here, and Mercury would rather bury their heads in the sand and hope it goes away, than to man up and deal with their fu-- up! This is totally contradictory to what they told my local deal - " that they have never seen this before"!!! Please keep posting on this thread so if this ends up in court I have some backing/statistics. Thanks, Steve
300xs Engine cover
By Toger13 in forum Parts WantedReplies: 13Last Post: 05-16-2015, 08:41 AM -
1996 Skater 28 For Sale - 2013 Mercury 300xs with Warranty
By SupremeSteve in forum Ebay Listings and Other Internet ListingsReplies: 5Last Post: 03-01-2015, 08:48 AM -
2013 Mercury 300XS
By marty3 in forum Outboard EnginesReplies: 4Last Post: 02-11-2015, 09:02 PM -
17v bullet backsplash rear cover and bow panel cover.
By south599 in forum Appearance ModsReplies: 1Last Post: 08-22-2013, 09:28 PM
